what size are those fans bkbroiler?
Ok, got the back plate. Looks good so far. I'm frustrated that I didn't get enough time with this over the weekend. I need a drill bit to make the hole next to the 92mm fan larger so I can mount the fan controller, but daylight savings time screwed me and I waited too long to go to the hardware store - grrr. Anyway, long story short, I'm still working on this, but here are a few pics that should give you an idea of the overall finished product. I'll have much better pics when I can have a little photo session in the daylight hours
Here is a pic showing where I shaved away part of the case, allowing me to assemble everything outside the case:
Here is a little preview of what the final product will look like:
Hi man you can install a noctua c12 with dfi jr p45 and can pull off the motherboard tray with nocuta is installed ? with the mod in the left frame too ? Thx
Not a chance. I'm in the process right now of installing the same m/b and heatsink. Any rotation you choose will not allow the m/b tray to slide in/out with the heatsink installed. I had to cut out a small notch about 2 inches long and about 1/4" wide to allow the edge of the heatsink fins to slide through. Also, I checked and there's no way w/o heavy mod that you can get this to happen with the fan installed. No biggie for me tho.
rEVjon
Did you cut into the 5.25 bay to fit your wires through?
You only need to cut this much, to fit the noctua c12p.
sorry for the blurry picture
EDIT: It looks like you have a different bolt layout for your backplate, that one on the left top looks to be in the way.
@bkbroiler
great work at backplate.. im having exactly the same intentions with adding exhausting fans but i dont have the case yet to make measurements.. is it possible to use 80mm fans instead of 70mm (from the pictures it seams like there is 1cm above&below)? Im asking this as im unable to find any store in EU that have 70mm fan grils which is quite non-standard size for fans
ok, bad news. the ninja will not fit. it is 2-3 mm to big.
so i will give Thermalright`s High-Riser HR-01 PLUS a chance...
