lian li pc-q25 server build input
cmge
ive been tinkering of the idea of making my own server to replace my old hp mediasmart ex490..
something like this:
http://hardforum.com/showpost.php?p=1039005115&postcount=656
i really like the lian li pc-q25b but a part of me really wants to modify the front so it can have better air flow inside with a bunch of hdd's inside it...
maybe im just paranoid but should i desecrate the lian li and drill holes to it to provide more air flow kind of like the pc-q18b?
i havent settled on the mobo since i need to find one with lots of sata ports or maybe just buy one of these:
sata port multiplier (would this work?)
http://addonics.com/products/ad5sapm.php
and not worrk too much about a mobo with lots of sata ports... as for the cpu i think id like to use the i3 3220...
what do you guys think?
any input would be appreciated.. thanks
cmge
thank for the input wirerogue
crap i just noticed i posted this on the wrong section... :S
