yesVery nice Silver
Your config?The psu, is a Silverstone ST45SF ?
Has anyone else noticed that the PC-Q08 doesn't have those "slots" on the bottom of the PCI bracket holes that the ends of the PCI cards are supposed to slip into so they stay in place?
Nice case, but does anyone here know of a similar case, but made out of steel? I hate how aluminum cases doesn't quite match up with the plastic bezels of my optical drives.
This case has an aluminum DVD "door", so style concern is already addressed
(Slots circled in red)
My problem with this is that my video card only takes up one slot. In my other slot is one of these 4-port USB bracket things:
When I try plugging anything into those USB ports, the whole bracket pushes in since it's only secured at the top where that lip is that the bracket rests on and is attached to with one screw. Same thing happens with my video card when I try plugging my monitors into it.
It will fit if you take the bottom cage out.
Yes.Are you 100% sure?
Quite frankly, I'm not sure that assembly uses standard 3mm or 5mm LEDs ... but would like to know the answer to the question as well (my bet is that it's NOT 5mm)Anyone know if the red LED in the reset switch is 3mm or 5mm? I'm going to replace it with a white LED, but would like to know the size before taking everything apart to get to the LED.
Took apart the power / reset button assembly and the LED used on the reset button looks like a surface mount LED, pre-wired and sitting in what looks like a LED holder for a 3mm LED.Quite frankly, I'm not sure that assembly uses standard 3mm or 5mm LEDs ... but would like to know the answer to the question as well (my bet is that it's NOT 5mm)
Has anyone tried attaching the radiator for a H50 to the front 140mm intake fan yet?
here it is
i attached the rad and 140mm fan with an adapter that funnels the air down to the 120mm rad.
i started out with just the 140mm fan at first, but then i realized there was almost no air making it through to the backside of the rad so i added another fan and went with a push pull setup. after that my CPU temps dropped 4-5C and my GPU temps dropped 2C from the extra air it was getting.
obviously you have to lose the HD racks and you lose a lot of video card room, but i went with an SSD and a 500gb laptop HDD for storage and mounted them with with velcro. there is definately room for a 3.5in drive instead. my video card is the 8.25 inch gtx 460 which i bet is more than enough power for 90% of the gamers out there
here it is
http://a.imageshack.us/img192/9617/picture2nx.jpg
Corsair H50 w/Scythe slim fan. Zotac H55 mobo.
Perfect fit
