Had this case just collecting dust and it was just asking to get some holes cut.
Only modding I did to this was 3 holes cut, and some switching around of the panels. This is the result.
This was the mach up of the panels being swapped around and put on it's side.
Took my drill and 3 minutes later.
Tossed some stuff on it and POOF!
Total time of modding was about 45 minutes. But it's pretty slick I think =)
I also talked to lian li and they are going to send me a PCI bracket from their test benches so I can mount it up.
