sblantipodi
- Aug 29, 2010
Hi all,
do you know if Lian Li O11 Dynamic can fit E-ATX mobo without problems?
Thanks
Thanks
google not working?!
M/B Type E-ATX / ATX / Micro-ATX / Mini-itx
http://www.lian-li.com/pc-o11-dynamic/
but that's not what you asked. it should be fine as that issues was taken into account, note the angle of the pass-throughs.
Just got this case and I can confirm as I have an E-ATX board, they will fit fine but the longer/wider the board, the more overhang you'll have.
is there the possibility that the board will touch the side fans?
The only way I could see that happening is if you have a rad plus fans on the side. There's a good amount of clearance, though.
