TheBlueChanell
- Apr 15, 2005
Anyone know if an H100 would fit in the front of this case?
Hello there, first time I post here.
Sorry for my bad english, but I think you´ll understand me.
I want to build my new PC into the PC-A04 and want to install a Corsair H60 or something like it in my System.
I found different threads about this theme but a answer is still left.
Can anyone here give me the answer if the H60, H50 ....... fits in the front of the PC-A04?
I found a Picture from a V354 here, and it shows exactly what I wanna do with the PC-A04.
http://i186.photobucket.com/albums/x267/bradmax57/P1030102.jpg
I wanna fit the Corsair Cooler on the lower 120mm fan in push pull (2 fans) by removing the harddisc cage.
I think it could work, but I never seen a picture or something else from such a config.
The fan positioning in the PC-A04 looks quite even, but I could not appraise how wide the PC-A04 at this area is.
At pictures it seems that the frame of the case could get in conflict to the radiator, because it would be mounted crosswise like in the picture of the V354.
I ever read about guys who want to mount this cooler into the top of the case and how they get in conflict with their motherboards but never heared about one who tryed to mount it to the lower front fan.
Thank you guys, for reading this, and I hope anyone have pictures or could do some measuring at his one PC-A04 to give me an answere.
Oh sorry, for the less informations, I thougt it´s needless to say, that I would remove the bottom HDD Bay (small one) and mount it under the 5,25cage. The Big HDD Bay will be removed completely.
In a worst case scenario I also be able to remove both HDD Bays because I only would mount a SSD in this System. My Data Music....... are all on an extern HDD.
But it´s also nice to could if you need, so i prefer the version with small HDD Bay under the 5,25 like in your picture![]()
my A04
Can I please see a pic of the rear? Did you cut the Case to fit the radiator?
Where did you pick up your 80mm-120mm adapter? Was the fit difficult at all? Your case is gorgeous. I would like to run a similar setup, an H50 in my Lian Li A04.my A04
Hope you guys don't mind the "late" bump, but I just received my case today, and was hoping to find someone who has decent to above average cable management in this case, but I haven't found a single person who has done so.
Is cable management non-existent or do you guys just set these up quickly and call it a day?
I'm planning on some cable management clips or whatever, similar to these, just found locally:
http://www.frozencpu.com/products/12622/cpa-544/Lian_Li_Cable_Management_Kit_-_PT-CL02.html
Was hoping to find cable management tips, aside from a modular PSU. Anyone have any tips?
i used 80mm to 120mm fan adaptor to mount the rad, no mods done
I just received mine. The quality of this case is top notch.
I need to do some more wire management and make it all pretty in there. One day I'll do it. Used a nexus 80/92mm to 120mm adapter. H60 put in place of the old after market cooler I had in there. I have already seen a 15* F drop.
