The airflow would need a little tweaking. The biggest issue I'd have with that is the power cord sticking up out of the top of the case. You'd have to create another lid to go over it like the RV-02 to keep that clean look.
That's surprising that the NSK won't fit the NH-U12P. The A04 just barely won't clear yet it doesn't have the space to fit a 120mm fan on the back panel, but the NSK does have the 120mm.
Anyone know why these were taken down from Newegg (or was it just a sellout), and if/when they will ever return? Really would like to get one, but can't be found anywhere.
@frankle: I'd probably go with the A04 if you can find one. That may prove to be rather difficult though.
I wouldn't hold out for one right now. There's no word on when any might show up, if at all. Could be days, weeks, months, or never... If you've got another case you can use for now then waiting wouldn't be so bad.
Yuck...this certainly scares me. Anyone know why this occurred (sellout or recall?)?
wow.. Willister I just want to thank you again for the trade.. It looks like people really want the case right after they took it down.. maybe they wouldn't have taken it down though if all these people had bought it before though.
So time for a vote ... PC-A04 or NSK3480 ??
The v354 isn't really smaller. it's just proportioned different.
v354 volume is 35.28 Liters
a04 volume is 33.38 Liters
So the a04 is actually smaller.
Either you have different measurements than the Lian-Li site or you made an error in your math on the V354 volume
All measurements below are taken from the Lian-Li site:
V354 is (W) 245mm x (H) 320mm x (D) 420mm = 32.9 litres
A04 is (W) 188mm x (H) 386mm x (D) 460mm = 33.3 litres
AO5N is 210mm x 381mm x 490mm (W,H,D) = 39.2 litres
As I said on page 8, it should be doable, but it's a tight squeeze. The screw for the lid is right up where the top fan would be. 2x92mm definitely will not fit.
Hi,
just registered to share some info on the a04.
Currently building my new pc with it and a good cooler/fan combo that fits to consider is the Gelid Tranquilo. good reviews all around.
Will see how good it is in the case.
this case doesnt work with the lian li cd drive stealther bezel thing right?
due to the fact that it has those tooless things on the side?
Black is back in stock at NewEgg and if you received coupons in the mail for 15% off any Lian Li case, it wipes out the shipping cost with the 15% off.
