Lian Li 011D XL Rog vertical GPU mount
Discussion in 'Cases & Case Modding' started by doox00, Jan 7, 2020.
  1. doox00
    doox00 2[H]4U
    2,967
    Aug 28, 2005
  2. Dan_D
    Dan_D [H]ard as it Gets
    55,346
    Feb 9, 2002
    The CableMods vertical mount will work perfectly with that case.
  3. doox00
    doox00 2[H]4U
    2,967
    Aug 28, 2005
    Okay, I will check that out, thanks.. I have the older lian li 011 xl dynamic case that came with a gpu vertical mount bracket.. this new case has a vertical slot cut out in the back (with a cover) where it seems the gpu would go.. the cablemods bracket utilize that slot?
  4. vegeta535
    vegeta535 2[H]4U
    3,562
    Jul 19, 2013
  5. Dan_D
    55,346
    Feb 9, 2002
    I'd need to see pictures of what you are talking about. The PC-011 Dynamic I did a build in recently didn't have anything for vertical mounts in it. However, the expansion slot area was ideal for the CableMods bracket as the slots had nothing in between each of them. They just used the screw in slot covers and that's it.
  6. doox00
    doox00 2[H]4U
    2,967
    Aug 28, 2005
    I had emailed lian li before I posted this thread too, they replied and said the one vegeta posted is the one to use. Here is the slot I was talking about though.
  7. Dan_D
    55,346
    Feb 9, 2002
    That's unique to the XL model then. In that case, you don't need the CableMods one as its designed for cases without provisions for vertical mounting GPU's.
    doox00 likes this.
  8. hijacker
    hijacker Gawd
    877
    Mar 20, 2002
    I just built my system in the XL and vertical mounted my GPU.
    I used the same as vegeta's link
    (still have some wiring to clean up).
    vegeta535 and doox00 like this.
