LGA 2011 motherboard with no cooler mounts
Aku12
I recently ordered a mITX x79 motherboard from aliexpress. (https://www.aliexpress.com/item/1005001321699528.html)
I got caught of guard building the computer today because the mounting holes do not have threaded inserts in them. every LGA 2011 motherboard I have worked with had them. If you look at the picture at the link above it does show that they do not have them. It came with a plastic bracket with plastic anchors. Is there a way I can get threaded inserts/studs.
I notice LGA 1366 has the same hole spacing but does not have these inserts. Would I be able to use a LGA 1366 backplate or would the back side of the socket interfere with that?
Thanks!
auntjemima
Thanks!
The hole spacing is the same on about 14 different Intel sockets. So, yes.
D-EJ915
You could probably cut the "ends" off the 1366 plate, the threaded screws that go through the board to the socket clamp mechanism are in a different location so you can't use it directly with a 2011 socket. They also have plastic notched keys on the 2011/2011-3/2066 sockets so you can't use an x79 socket on an x99 or x299 either lol.
There are some on ebay though as an example:
https://www.ebay.com/itm/303294364512?hash=item469dc0bb60:g:ApIAAOSwVttbCiAr
https://www.ebay.com/itm/3241048507...LbV6ssWtzHZJfuQEmWbvgH3huek9T5FgaAilfEALw_wcB
Reactions: Aku12
Aku12
I never thought about just replacing the socket retention itself. Thanks!
