tI've had this monitor for a few days now, but I may be taking it back.
My primary use is FPS games like CSS, but I also use it for web surfing, photo editing, etc. I initially bought it because it appears to have lower input lag than the Dell or BenQ 24s, and indeed it looks, feels, and plays great in games.
However, I believe Roach is right about the text. In native resolution (1920 x 1200), the black-text-on-white-background looks a little fuzzy. It's not profound--you may not even notice if you have nothing to compare it to, but I hooked up a Dell 19" LCD and a Samsung 244T to the same computer. Both of those LCDs display crisp black text. The LG246 has a little bit of smear to it--subtle but definitely noticeable. Maybe it's the coating as Roach hypothesized.
I'm really pi**ed--everything else is great about this monitor, but the not-perfect text is probably a show-stopper for me. (Yes, I have the latest drivers--running a GeForce 8800GTS with Forceware 162.28 drivers.) Oh well...
...that monitor has horrible viewing angles, even if you sitting straight in front of it...
If you leave HDMI on "PC" mode there will be noticeable cropping on the left side. If you put it in "Video" mode then there will only be minor cropping on both sides.Can someone with a PS3 do me a favor? Open up the web browser and see if it is cropping the left side of the screen? You will see on the upper left hand side a "WWW" icon and mine is getting cut off slightly. I cant be sure if its just some games/apps or the whole time because its not enough to really notice in most cases. Want to make sure its not just my monitor either.
Correct.Also, when you adjust the DPI in Windows XP, that setting is only for Windows and doesn't affect the PS3 right?
I just bought a L246WP from CompUSA.
I cannot access the EZ Video option in the menu, nor can I get ForteManager to work (it will show me all the info about the monitor, but all of the adjustment options are grayed out).
I've seen mentions about this in this thread, but no advice as to resolution.
Can anyone help me out here?
I would greatly appreciate it.
Damn... The text on this thing is some of the crispest ive seen. makes reading sites/docs so much easier... BEFORE I updated my drivers the text looked like shit.. so not really sure whats going on with some of your video cards..
People have mentioned changing the DPI and also messing with the "ClearType" settings... try that maybe?
I finally gave up at BestBuy and bit the bullet once I realized this monitor did HDMI and had Component Input. I also just ordered the HDMI monoprice switch so hopefully I can use ps3/PC simultaneously.
would u plz try to connect the PS3 through HDMI n post the result for me coz am between the LG and the BenQ
Just picked up the LG 246W today at BB. I spent about a week going back and forth between a 1080/720pLCD TV for $1300-600 and a couple of days crying over how the 37w3 is impossible to find. Also drooled over the Benq but slapped myself in the face because of the price difference, I finally gave up at BestBuy and bit the bullet once I realized this monitor did HDMI and had Component Input. I also just ordered the HDMI monoprice switch so hopefully I can use ps3/PC simultaneously. So far I'm very impressed, just a tiny bit sad I still have yet to buy my first HDTV... quite a step up from the 2007wfp, viewing angles aren't bothering me as much as I thought they would.
Few questions:
1) Is VGA better than Component for xbox 360? My picture seems a little washed out when using either of these inputs with the 360... need some adjustment tips!
2) I read previously some owners had issues with the monoprice HDMI switch and using their PC after a switch... It sounded like an ATi driver issue but does it affect my 8800GTS equally?
Ps3 works great w/ HDMI @ 1080p "Original Mode"!
thanx alot man....one last thing...is the compnonet input any good?coz am thinking of hooking up a DVD player through it?
Whoodie: thanx for ur comment....so u think it aint worth it the extra money for the BenQ...all am getting extra is a DVI,Composte etc..?
any idea about best prices for the LG?
i remeber i saw one at Best Buy bt it didn have a Component..only VGA and HDMI?or am wrong?
I haven't been assured that the LG doesn't have scaling problems either. Several people mentioned cropping. Is 1080p cropped or not? What about 1080i and 720p? Is 480p and 480i scaled correctly? How's the deinterlacing? Nobody has been clear about any of this.Whoodie said:Go read the BenQ thread. For PC only the BenQ is fine, but for consoles the LG is the only way to go IMO. The BenQ has to many scaling issues for my tastes and the firmware update seems like too much hassle. I am perfectly satisfied with the LG. You should get it at BestBuy, that way if you don't like it it is returnable. There aren't any B&M stores that carry the BenQ.
There's no DVI connection, but there is HDMI. HDMI is just DVI plus sound, so you can convert back and forth between HDMI and DVI with absolutely no change in the picture. They're completely equivalent in this respect. The monitor comes with a DVI to HDMI cable, so if you want to use this with a PC, you plug the DVI side of the cable into your video card and the HDMI side into the monitor. No need to buy anything else or to use VGA.Okay here is a big noob question: Does this monitor have DVI? I mean, can I plug it into my computer using DVI cable? Or must use VGA?
Sorry, I just got very confused reading all the posts in this thread and seeing "HDMI > DVI converter" and such things I'm not clear on
