@JyuOH
no one knows, try searching google or call/email LG
mindaugas doesn't have a console. He has already pointed that out earlier.
Why do you need an interpolution control on your display if it is connected to your computer? I mean you can control the interpolution behaviour in your graphic cards driver. In case you connect the display to a device that doesn't offer this options e.g. a dvd player or a gaming console it is a nice feature though.
The first option streches any signal to fullscreen. The second option forces any signal lower then 1680x1050 to be displayed with the native resolution of your display. This causes black bars all around your image. Their size depend on the resolution you have chosen. The lower the resolution, the bigger the black bars. The third option streches your signal to fullscreen again while keeping the aspect ratio. You can see black bars either on the left and right or on top and buttom. (Sorry for the bad language. I haven't used it for a while.)
1. 640 x 350 (70 Hz)
2. 720 x 400 (70 Hz)
3. 640 x 480 (60/75 Hz)
4. 800 x 600 (60/75 Hz)
5. 832 x 624 (75 Hz)
6. 1024x768(60/75Hz)
7. 1152 x 870 (75 Hz)
8. 1152x900 (65 Hz)
9. 1280x1024(60/75Hz)
10. 1680x1050(60 Hz)
The setting method can differ by O/S or video card. In this case, Please ask to the computer or the video card manufacturer.
Guys is it possible the whole 2ms mess is because the 2ms value is for GTG while the 5 ms is for white to black measurements?
Isn't this very much depending on the adjustment of a display?
The brightness is often set to high. Lowering the brightness will reduce this effect significantly.
Do you have a nVidia or AMD/ATI card in your notebook?
Nvidia 7900GS
Sirs
I'm am in my second day with a WT-BF. Four units arrived in pittsburgh at one BB location only.
Just happend to walk in.
Now I'm glad I did. My 6yr old NEC 1850 expired.
This Monitor is fast and steady, Dynamics? eh....
I use an Autumnwave GT USB hdtv tuner PVR, No lag on screen and get a Sharp 16:9 High def picture.
Basketball Game was intense. No jerking or smearing. A New PC expirence for me.
Bleed is hardly noticeable, this panel and all lcd panels should have a cast frame instead of a stamped frame to solve bleed through.
Stand doesn't pan, rotate or rise. I'm using a connect3d 9550 no fan.
I'm set up for Audio production. Viewing angle pretty good, better than I expected.
Real Nice Panel. I was expecting a three year warrenty, 45 buck BB warrenty.
Turning the Gamma Off after reset is my lone adjustment after reset. That solves the brightness for me.
Squish
The warranty IS 3 years for CRTs and LCDs, as mentioned on LG's website.Real Nice Panel. I was expecting a three year warrenty, 45 buck BB warrenty.
I don't think LG offers 0 dead pixel warranty for monitors above 19''.What about 0 dead pixel warranty?
I got mine today... at first colors were really washed out at default settings... I messed around with the brightness and contrast and really wasn't getting a picture that I wanted... colors were still washed... so, I set the gamma to zero or at the lowest level and voila, colors are awesome!!! I fired up WoW and I am VERY VERY pleased with what I see not to mention the game was meant to be played Widescreen mode...
I highly recommend this product!
Sir spincut
Yea I here ya. but 3.3 to 5.9 is an octave leap.
My NEC went south about 2 weeks ago, I have changed nothing, just added the driver and monitor.
I'll guess it's Aero Glass Voodoo. Mabye something to this Aero glass process after all.
Squish
Thanks for the pics mindaugas, may I ask where I could find a computer desk like yours?
cheers!
