Don't go believing that this is a true 8-bit panel. There has not been a single 8-bit TN panel, in the whole wide world. They all use dithering to achieve "8-bit", to this date. LG is usually full of crap when it comes to listing panel specs.
With the way LG lists their specs, 3000:1 is measured in the most perfect and rare, controlled situation imaginable. You'll never come from 1000:1 all the way to 3000:1 just because of the backlight.
What is this "dithering" they use to achive 8bit? (asking for the 225BW samsung!)
Any pics comparing an S-IPS to a TN? I want to see how big the difference is
1000:1 is the base contrast, 3000:1 is the dynamic contrast using the Digital Fine Contrast technology.
explain, so is digital fine contrast on all the time then?
also, everyone seems to be focusing on the 22 inch model, but what about the 206 and so on? are is the entie new 2x6 series TN, or is only the 22 inch TN and the rest of the new ones are IPS? cause i wouldnt mind getting a 20" IPS....
Wow, that's quite a price tag for a 22".
Edit: On the upside, th review says the monitor is big enough to cope with peacetime use, so that is a plus.
Is L226WT-SF the same thing as L226WTQ-WF?
So is this thing going to come out yet or what?
Do we have any confirmation this monitor is even coming to the U.S.??![]()
Or why the silver has 5ms and the black has 2ms! I guess it's true what they say, black is faster.Don't know why the latter has the fancy Vista logo and the former doesn't.
Word on the street is it will be launched at Best Buy at the end of January.
Or why the silver has 5ms and the black has 2ms! I guess it's true what they say, black is faster.![]()
Is there any other difference between the 226WT and 226WA than the WA having HDMI and component inputs? I noticed some sites say the 226WA has 2ms response time, whereas the 226WT has "only" 5ms as well.
The price difference between the two was negligible though (WT 389€ vs. WA 409€, so I ordered the 226WA.
Where did you get this information about the 226WT vs 226WA?
And where did you order?
Thanks![]()
Answer to first question is here, although there is no mention of HDMI or Component input:
http://announcements.engadget.com/2007/01/05/lgs-got-5-new-lcd-monitors-for-you-and-you-and-you/
I ordered the monitor from a local shop here in Finland that carry a lot of LG products. I got the specifications from a German online shop though, as the shop knew nothing except that they might get them on the 30th of this month, hopefully...Where did you get this information about the 226WT vs 226WA?
Thanks![]()
226WA
Videoeingänge HDMI/DVI/D-Sub/Komponente
Response 2ms (ISO Messung)
226WT
Videoeingänge 15-polig D-Sub / DVI-D
Response 5ms (ISO Messung)
