How can an lcd get burn in? I did a lot of texting today and all night i have had a keyboard burnt into my screen. I have not seen ir on a lcd since the early lcd days. Its worse ir then if you leave a plasma on a desktop for a few hours
I have never seen a full keyboard 100% readable on the gray screen of [H] on any phone even oled phones before. Ir on the bar at the top yes never on the main screen.Happens to all LCD eventually. Just a matter of time.
It'll probably clear out -- persistence, not burn-in. Though... very odd it happened in the first place.
no way to prevent it
Well there is...don't keep static GUI elements on the screen long term.
If you don't exercise a muscle, it atrophies. Same with a computer screen. Every pixel needs worked not infrequently. Screens that get pixel-permanence or burn in are usually running OSes with locked or semi-permanent GUI elements...like the Android navbar or signal icons, or the Windows task bar or the Apple toolbar etc.
Yes. I have an LG G5 and I've seen this on other G5's. Mine does it really bad. There's something wrong with the chipset or screen they used. It's screen retention, where the previous image isn't being cleared correctly and lingers for a while until it eventually disappears.
That's why I like the customization of Android. Removed the Nav bar completely and use LMT pie controls, and allow some apps, like Chrome, to go fullscreen so there is no status bar unless you drag it down.true, but everyone does it... even app icons, clock, google search bar, you can't really prevent it.
from http://forum.xda-developers.com/lg-g5/help/screen-burn-t3364676/post69242263#post69242263lg g5 only last 3 secs on burn test, because of the thin gg4 glass, high brightness cause the screen to heat up and the thin glass cant hold enough heat thats why the screen ghosts up easily. the app blue light filter at 5% can prevent all screen ghosting and not drain battery at all.
