elvn
- May 5, 2006
A lot of games are 65, 85, 110 fps now at 4k. Maybe 80, 115, 125fps tweaked/dialed down from ultra to "VeryHigh+" custom.
I doubt you'd need raytracing to be 150fps average and less on the most demanding, long view distance + animated objects in the distance type games of now and whatever demands/graphics ceilings in the next few years of games.
So sure depending on the game and settings you'd get some benefit rather than being capped at ~ 117fps . . even at 144Hz or 165Hz capability . . if some of your games are in that range but you will likely still be a good stretch away from 200fps+ to 240fpsHz peaks.
I've heard the 200% performance increase claims before. It ended up being like 25 - 30 fps better at 4k in some games with the 3000 series' top cards vs 2080/2080ti. I'd expect around the same so in my example above using a conservative estimate of 25+ fps increase:
65, 85, 110, 115fps now on ultra ---> 90, 110, 135, 140 average or so.
80,115, 125, 130fps now (dialed setting down from ultra) ------> 105, 140, 150, 155 or so.
I'd say most of the better well performing games on that list were at:
100, 110 fps on ultra now ----> 125+, 135+ fps
115, 125 fps dialed down now ---> 140, 150 fps
The more demanding and yet good number of very popular games were at around:
60, 68, 80 on ultra now ---> 85, 93, 105+ fps
75, 83, 95 dialed down now --> 100, 108, 120fps average
If feeling generous, add +5 fps to those guestimates on the right side of the equation. And do you think you are getting a Ti version right out of the gate? The 3090 came out sept 2 years ago (if you could get one). The 3090ti came out almost 2 years after the 3090 ~ april 2022 (well, 1y 6mo.?) and relatively shortly before buzz of the next gen drop.
I'd gladly be wrong about the 4000 series' 4k performance though. Will have to see some real world game benchmarks at 4k.
