I can't get networking to work properly between Vista and Leopard.
They are both set to WORKGROUP. I can not access the leopard machine from Vista at all.
In Leopard I can not find a way to see computers on the network, but I did enable SMB and can manually type if an IP address then always delete AFP and switch it to SMB to look at folders.
I even have a folder on the vista machine set so I'm a co-owner of it. I can start to transfer a file into it, and then near the end of the file transfer it just stops and disappears from the Vista machine.
I'm beginning to think networking between the 2 is just broken and that Apple will not work for the simple needs I need.
I'm open to any and all suggestions.
