I'm going to pick up a Canon EF 35-80mm f/4-5.6 III lens for cheap on eBay and try to find a 55mm lens reversal ring so I can start taking some macro photos with my Canon 40D.
Any tips for this?
Also, I currently have a Canon EF 28-135mm f/3.5-5.6 IS USM lens.
I was thinking about just picking up a 72mm reversal ring so I could use the lens I already have.
But I'm not sure if it'd be good for the lens since the weight would be supported by the end of the lens if it's attached by the filter ring which is fairly wobbly compared to the main body of the lens... Not sure if that would be bad for it or not since the lens weights just over a pound...
Comments? Suggestions? Tips?
Thanks.
Any tips for this?
Thanks.
