PontiacGTX
- Aug 9, 2013
I am looking to replace the memory thermalpads I wonder what PTM7950 pad should I use? 1.5mm thickness? is there any other alternative(which perform better)? thanks for your help
For RAM chips? Use K5-Pro and call it a day. Same for the other chips beside the CPU and GPU.I am looking to replace the memory thermalpads I wonder what PTM7950 pad should I use? 1.5mm thickness? is there any other alternative(which perform better)? thanks for your help
