I am not really impressed, for it does not seem to be worth the money
Source: PRAD.de
Conclusion
The Lenovo ThinkVision L220x is a solid screen with very good subjective image quality. The wide gamut display performs well with regard to the colour spaces AdobeRGB, ECI 2.0 and UGRA. The monitor could be an "insider tip" for graphics users with small budgets, since it performs well in the extended colour spaces.
However, the monitors result is limited by its excessive brightness. Use at 0 percent brightness is therefore to be seen as the norm if you wish to work at a level that is close to the recommended value for brightness (140 cd/m²).
In the office environment, the monitor represents an interesting alternative to conventional 22 and 24 inch models, since the Lenovo ThinkVision L220x has the resolution of a 24-inch monitor but the price-related attraction of a 22-inch monitor. The S-PVA panel scores points for areas such as viewing angles and pixel density. Those who are used to ultra-finely resolved text will gain an enormous working space as well as it and can work better in multi-window use.
Normal users and occasional gamers will receive a monitor with a low input lag. This is certainly suitable for their needs at just 31ms (less than 2 frames per second).
The L220x is a solid monitor with attractive performances for an absolutely reasonable price. Only the enormous brightness of the monitor spoils the otherwise very positive impression.
There is no real alternative to the L220x, since it is the first and only of its kind at the moment. However, if you find the text size too small but do not want to do without the advantages of a 22-inch monitor, you should opt for the Eizo S2231W.
Overall rating: GOOD
Source: PRAD.de
