I'm about to be putting together my first water-cooled PC, and I figure that before all the crap comes next weekend, I should do some reasearch. One of the best ways of avoiding problems is to learn from the mistakes of others.
The setup will be:
Dangerden AMD64 RBX
Athlon 64 3400+
Dangerden z-chip
Abit KV8-Max3
Dangerden Maze4 GPU block
Sapphire ATi Radeon 9800 Pro 256MB DDRII ( is basically an XT with pro BIOS from what I've heard ).
Eheim 1048 Pump
Blackice Radiator
Frozencpu tundra reservoir.
Cheiftec Dragon server series case.
edit: Swiftech HydrX UV reactive coolant.
edit2: 1/2" clearflex60 tubing
What mistakes/disasters have you encountered with a water-cooled system, and what could have been done to avoid them?
The setup will be:
Dangerden AMD64 RBX
Athlon 64 3400+
Dangerden z-chip
Abit KV8-Max3
Eheim 1048 Pump
Blackice Radiator
