pippenainteasy
- May 20, 2016
So, you're argument is that the Titan V OCs better than a card we've never seen OC'ed? Really? How do we even know this wasn't a factory freak? This is also 1 single game you're showing here. A game that's not particularly interesting because even a 1080ti can run it in UHD at substantially higher than 60fps (hell, the 1080 non-ti runs it >60fps).
[H] review shows the following for OC results on the Titan V:
Kingdom Come: Stock - 57.8; OC - 65.4 (13%)
PUBG: Stock - 59.2; OC - 66.1 (12%)
Wolfenstein II: Stock - 96; OC - 108.9 (13%)
ME:A: Stock - 63.5; OC - 71.9 (13%)
Sniper 4 Elite: Stock - 110.2; OC - 127.3 (16%)
The Division: Stock - 67.6; OC - 73.5 (9%)
Watch Dogs 2: Stock - 47.8; OC - 52.0 (9%)
I see nothing here that indicates that the Titan V OCs better than just about anything else out there. At least, not by more than maybe 2-3%, on average. And again, we've seen nothing about how the 2080ti OCs at all. Bearing in mind that the FE small OC is NOT the same as the [H] reviewers pulling out all the stops and pushing a card as far as it can go with 100% fan. Bottom line here is that it's a bit premature to make comparisons.
I'd also rather have a card that is a purpose built gaming card that I KNOW will receive driver updates for new games instead of having to use kudgey workarounds to get the best performance, as is the case for the Titan V.
I'm postulation it as a possibility since the 2080 3dmark leak was run at 2025mhz and that was barely faster than a 1080ti FE. We also know from Tom Peterson an average "top OC" is 2.13ghz, so the overclocking delta potential isn't huge, it's more under 100mhz compared to pascal.
