So I picked up a broken lcd screen for $4, opened it up had 2 leaking caps which I replaced. Turns on now but for one sec and turns off. If I unplug one of the CC it will turn on for about 5 seconds and turns off. If I unplug both CC it will turn on and stay but you can't really use it because there is no backlight. Everything is working on it except the backlight. There were three caps that were the same but only two were leaking, my guess is the third is bad also?
Also not sure if this causes a problem but the caps were 1000uf 10v, I replaced them with 1000uf 35v (only thing I could find remotely close in a store, shipping makes it the same price as a store). I didn't think a higher voltage rating would cause a problem since it just means they are little higher class.
