Apr 14, 2012 #1 S Samwiches Weaksauce Joined Feb 5, 2012 Messages 90 Speedfan hangs a bit when I'm running Linpack stress test, so I want it to autorun in high priority. I made a speedfan.cmd: Code: start /high speedfan.exe But it just loads with normal priority. What do I do? This is in Windows 7 64bit.
Apr 14, 2012 #2 X xxEIEIOxx 2[H]4U Joined Feb 1, 2008 Messages 2,276 Are you running that speedfan.cmd as Admin?
Apr 15, 2012 #3 S Samwiches Weaksauce Joined Feb 5, 2012 Messages 90 No. I tried that but it only loads the command prompt.
Apr 22, 2012 #4 R rive22 Supreme [H]ardness Joined Mar 10, 2004 Messages 4,646 This will do it for you. http://www.prnwatch.com/prio.html You'll have to pull up the default windows task manager to do it if you normally use process explorer, etc. But once it's done, it's done
Apr 23, 2012 #5 S Stoly Supreme [H]ardness Joined Jul 26, 2005 Messages 6,713 May I ask why would someone run speedfan in high priority?
Apr 24, 2012 #6 G Gman1979 Gawd Joined Sep 21, 2011 Messages 643 To make sure they're getting timely temp and voltage updates from Speedfan while the system is bogged down running the Linpack test.
Apr 24, 2012 #7 bigdogchris Fully [H] Joined Feb 19, 2008 Messages 18,707 I believe Process Lasso will allow you to automatically launch it with the priority you want.
Apr 25, 2012 #8 S Samwiches Weaksauce Joined Feb 5, 2012 Messages 90 I saw Process lasso, but Windows has got to be able to do this for me for free.
Apr 26, 2012 #9 R Ranma_Sao 2[H]4U Joined Mar 15, 2002 Messages 2,622 So speedfan.exe will run at high priority? An application can control which priority it's ran at... But the script looks correct, other than I would give the full path to speedfan. I also am not sure this will solve your problem, but it should work assuming SpeedFan doesn't monitor it's priority and switch it back. This posting is provided "AS IS" with no warranties, and confers no rights.
