Latest Messsage showing "too much"
Discussion in 'Forum Help & Feedback' started by Trepidati0n, Apr 6, 2016.
  1. Trepidati0n
    Trepidati0n [H]ardForum Junkie
    8,870
    Oct 26, 2004
    In genmay there are two password linted areas. That is cool. However, the subject, if the latest post, does show up. Considering how loose the rules are in those sub forums...some bad things that should be SFW may appear.
  2. RoldanLT
    RoldanLT HardForum Backend Admin Staff Member
    140
    Feb 18, 2016
    And you're not login to those 2 private sub forum?
    It should not show up unless you are login to those private forum.
  3. MajorDomo
    MajorDomo [H]ard as it Gets
    74,889
    May 9, 2000
    Log out and clear your cookies and log back in.....that should clean the slate.
    RoldanLT likes this.
  4. Trepidati0n
    8,870
    Oct 26, 2004
    Are there possible cross cookies? I've never done that (logged in) on this machine for very good reasons.
  5. Paul_Johnson
    Paul_Johnson [H] Admin Staff Member
    16,032
    Aug 29, 2004
    Trepidati0n is correct, I have run into this too.
