ellover009
- Jul 17, 2005
My last printer finally gave out, had an epson cx6600, good printer, but the ink kept plugging up the head and eventually the whole thing went. I've seen that color laser printer have gone down in price and whats making them appealing to me is that I think they are less likely to get the head jammed when the printer sits for a bit, depending on the season I end up using the printer more, and some months it just sits. Only thing that I find difficult to switch over is that they usually don't come with the scanner built, there really isn't much of a consumer geared one yet, but i've seen them go as cheap as $150.
I've also noticed there is a trade off, I noticed bw print cost in laser is quite a bit cheaper than inkjet, but I color prints I think are higher than inkjet, I am not too sure.
So do you recommend laser for my needs?
Is the color print of laser higher than inkjet?
is there even any good color laser printer that works on windows 7 64bit?
Does inkjet ink go bad over time if it's still sealed? Bought some for my cx6600 when compusa went bankrupt dirt cheap but I never got around to use it because my printer died.
