LapWorks Announces Gamers Desk
Discussion in 'HardForum Tech News' started by HardOCP News, Jun 19, 2008.
  1. HardOCP News
    HardOCP News [H] News
    0
    Dec 31, 1969
    A couple of you guys sent me links to this “gamers desk” lapboard and it looks like something you guys might / might not like. What are your thoughts on this?
  2. Skarth
    Skarth Limp Gawd
    485
    Mar 2, 2006
    The area for the mouse looks too small.
    Paying $40 for something to put your keyboard and mouse on sounds kinda stupid to me, some desks costs as much as that.
    Assuming you buy this because you don't have a place for your keyboard and mouse on your desk/whatever, then where do you place it when it's not in use? It doesn't make sense.
  3. Crucible1001
    Crucible1001 [H]ard|Gawd
    1,623
    Apr 7, 2005
    Well, it does not look FPS friendly with the mouse space. Might be nice for MMOs.
  4. MrLonghair
    MrLonghair [H]ard|Gawd
    1,764
    Jun 7, 2004
    Looks like it's the closest we will come to ever seeing the PhantomLabs lap-board. The z-board when used with a standard keyboard layout isn't bad, it all looks good but is there enough room for mouse movement?
    Current plastic mousemat is (misplaced my measuring tools so I'll have to measure in Wii remote lenghts) 1.3 x 1.9 wii remote lengths and it's just enough for everything I do.
  5. knob
    knob Limp Gawd
    291
    Feb 16, 2008
    Meh, I'm not impressed.
    My solid wood desk looks nicer, my standard keyboard functions very well, and my G5 laser mouse is quite happy on the nekkid wood.
    I'll keep my money for more useful things.
  6. babyhuey
    babyhuey n00b
    4
    Jan 26, 2007
    I think some of you are missing the point. Its for your lap whilst playing on a HDTV.
  7. InorganicMatter
    InorganicMatter [H]ardForum Junkie
    15,252
    Oct 19, 2004
    This isn't Infineon in disguise, is it?
  8. Gott
    Gott [H]ardness Supreme
    4,959
    Feb 28, 2008
    There's not a lot of real estate with the mouse. For the price and with what they're showing, it's a good concept but I think they failed to deliver the good.
  9. InorganicMatter
    15,252
    Oct 19, 2004
    Darn it, should have read Infinium, not Infineon. :rolleyes:
  10. Gorignak
    Gorignak [H]Lite
    68
    Aug 2, 2005
    As stated before, the mouse area is too small. I think the mouse will fall off of the lapboard if you happen to lift your left side higher than the right. A gyroscope with a pivot point about 6 inches higer than your lap would fix this.
  11. DaFox
    DaFox Limp Gawd
    393
    Dec 3, 2006
    LOL, no.
    Horrid keyboard and mouse on there too :rolleyes:
  12. inotocracy
    inotocracy [H]ardness Supreme
    5,625
    Jul 25, 2004
  13. CleanSlate
    CleanSlate [H]ardness Supreme
    5,129
    Mar 28, 2003
    I couldn't even use that thing to surf the web. The mouse pad looks waaayyy too small. I use about a half a foot of space to play CS. Gamers don't just need 3 inches of room to play. Besides, that encourages wrist problems.
  14. needmorecarnitine
    needmorecarnitine [H]ardness Supreme
    4,605
    Feb 10, 2004
    I made something similar to place my wireless keyboard and mouse. I used it for everything not just gaming. As almost every has already mentioned, the mouse area is too small. $40 is way too much for that crappy design. If it was done really well, and looked nice, it could get $20. Anyone can go to Home Depot and get them to cut melamine coated particle board to their specs and it would cost less than $10
  15. magoo
    magoo [H]ardForum Junkie
    14,337
    Oct 21, 2004
  16. Zero82z
    Zero82z [H]ard as it Gets
    27,897
    Jan 20, 2004
    Looks like a piece of shit, but at least they beat Infinium to it :D.
  17. AceGoober
    AceGoober Live! Laug[H]! Overclock!
    21,232
    Jun 25, 2003
    I'm not too keen on the design. No wrist support.
  18. Skarth
    Skarth Limp Gawd
    485
    Mar 2, 2006
    Even if this is used for websurfing on a HDTV, theres a number of far better alternatives that would function much better, such as keyboards with trackball mice integrated on them.
    example - http://www.fentek-ind.com/kbmrfotb45ub.htm
    Thats more expensive, but if you shopped around, I'm sure you'd find something similar for $40, or less.
  19. Gorankar
    Gorankar [H]ardForum Junkie
    10,148
    Jul 19, 2000
    I also think the mouse area should be a bit larger. Used with a good cordless mouse and keyboard, (not what is in the pic), I could definitely see this being popular with the HTPC crowd, or the PS3 crowd that actually plays UT3 with a KB/M.
    Ehh, there would be room for a larger mouse pad area if a keyboard without a num pad was used.
  20. MrVTEC
    MrVTEC n00b
    32
    Feb 19, 2007
    I'd buy one just because I hate having to lean over the coffee table when playing games on my TV in the livingroom. Even with my mouse pad on a book on the couch it doesn't feel right. I'll give one a shot if the price isn't too steep. Looks much better than a piece of plywood across your lap.
  21. snaggletooth
    snaggletooth [H]ardness Supreme
    4,746
    Aug 16, 2005
    obviously most of your desks are going to be better than using a LAPBOARD. you know... for your couch-lazing needs.
    i'm in the market for a solution like this right now, though i'm in agreement about the limited mouse area.
  22. Gorankar
    10,148
    Jul 19, 2000
  23. kuyaglen
    kuyaglen [H]ardForum Junkie
    9,230
    May 15, 2002
    I could see myself using that, if I were using a large screen monitor/hdtv and sitting on a couch. :)
  24. Nenu
    Nenu [H]ardened
    18,626
    Apr 28, 2007
    Try the Razer Deathadder mouse.
    It works wonderfully on my sofa/arm with no mousemat.
  25. bob
    bob 2[H]4U
    2,971
    Feb 13, 2002
    No one missed the point. $40+ for a rectangle to set your keyboard and mouse on. $2 worth of MDF from home depot does the same. Add in some work with a jigsaw and router, and you have a custom one to fit your keyboard, mouse AND lap. Not only that, but the thing seems too small to be of any use.
    Its not a bad idea, its just that people who can operate a jigsaw, or at least walk into a lumber store, hold their arms up in the air and say "i want it cut it this long", can do it for far cheaper.
  26. Techx
    Techx [H]ardness Supreme
    4,380
    Dec 30, 2002
    wow the mouse in that pic is the OLD OLD logitech dual optical.. used to love that mouse
  27. jaffy
    jaffy [H] Custodian
    5,559
    Jan 13, 2004
  28. Tbird87
    Tbird87 Gawd
    917
    Jul 16, 2003
    small mouse surface is small
  29. Godmachine
    Godmachine [H]ardForum Junkie
    10,472
    Apr 7, 2003
    Looks uncomfortable and frail .. I could see my-self breaking that accidently.
  30. DoggyDaddi
    DoggyDaddi Gawd
    783
    Sep 10, 2002
    That's the Targus lap board.. msrp $17 at Wal-Mart guys.. way to be retarded
  31. AOM
    AOM Gawd
    960
    Aug 12, 2004
    Did any of you check out the actual page where the product is listed? It barely weighs over a pound, and is 26.75 inches wide/long.
    My keyboard is (the zboard pictured actually) 18 1/2 inches wide/long ..so that gives me 8 1/4 inches roughly for using my mouse.
    My mouse pad is 11 3/4 inches wide and honestly I use about half the space if that. I have a logitech mx 518 gaming mouse and I don't have to pick up my hand and move it 2-3inches to play an fps or other games like some people I've seen play at lan partys etc, so to each his own.
    I could see this setup working well for me in the next fews months when I build my new gaming/htpc to use on my Sony 52" 1080P HDTV. So for me I think it could work well and it looks well constructed imo, plus I know their laptop products are super nice and they offer them in some nice finishes.
    The article said they were also going to include some custom finished for this product as well.
  32. gaspah
    gaspah 2[H]4U
    2,373
    May 29, 2007
    i say a desk is crap.. get a 42"+ screen and a wireless gamepad for your pc...
  33. arasta
    arasta n00b
    29
    Jan 31, 2008
    with the way i mouse atm i only have to shift it 1 inch in the Y and 2 inch in the x axis to move my cursor edge to edge of a 16x10 desktop. sure you will need a bit more space on the end for when it gets frantic in a FPS but as noted its not really the target market for these. if you swing that way a second version with a bulge at the end to accommodate FPSers would be good?
    id be interested in something like this. the only problem.... we dont have walmart in Aus yet, tho im told costco is coming....?
  34. IronBits
    IronBits Limp Gawd
    154
    Jun 24, 2001
    Keyboard trays are what cause carpal tunnel. I'll never use one.
  35. babyhuey
    babyhuey n00b
    4
    Jan 26, 2007
    I was referring to these two quotes.
  36. Thor
    Thor 2[H]4U
    3,882
    Jul 23, 2001
    it looks like it is about as big as my g15... so thats a no go.. and 2.. its not made of ratpads material... after i got used to useing this pad, i cant use any thing else...
    hey kyle.. i gots an idea.. :p
  37. Steven301
    Steven301 Limp Gawd
    275
    Jan 29, 2002
    Logitech diNovo Mini. Used on windows base pc's and ps3, some got it to work for xbox 360. Used for sending messages and controls the 3 systems above with no need for a brace.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16823126039
    LInk to item, I know some will say that its cost kind of kills the cut some cardboard but for thoughs that want something that works and looks good comes in handy when you have 1 remote ( logitech Harmony 1000 combined with mini above ) :D
  38. Leman
    Leman Gawd
    909
    Jul 15, 2007
    Listen to this man.
    Granted, wrist support sucks. Although if you're using a keyboard as big as that, you're going to have to be a twitch player. You know, maxed out Windows and mouse driver sensitivity.
    If it was wider, it might be better. I'd rather stick to my easier and cheaper solution of using a foot stool as a keyboard rest (legs go under the cushion, fit nicely), and the mousepad goes on the nearby table.
  39. Chris_B
    Chris_B [H]ardness Supreme
    4,997
    May 29, 2001
    Mousing area as said is too smal. What did happen that infinium labs lapboard anyway?
    Ed:
    http://www.phantom.net/home.html
    ooh its actually available to order. probably wait 2 years before you see the thing.
  40. Ididar
    Ididar Gawd
    594
    Aug 2, 2004
    Sand down the edges of the plywood and put a coat of paint on it. Thousand times better than dealing with the small mouse pad area on this thing and save yourself a fortune. Heck, just go pick up a piece of primed MDF shelving and cut to length desired. Nice hard surface.
