I am trying to copy a system partition between two identical laptops.
I connected the laptops hd to my main computer and used microsoft's backup utility to backup the old system, then connected the new laptop and performed a restore... The laptop makes it to the windows logo just before login and hangs there (doesn't freeze, but does not continue further)... What could be the problem?
If all else fails do you think ghosting it using this method would be successful?
