Laptop has mini DP and monitor has USB-C, how to connect the two?
rcrez
I'm having trouble connecting these two. My laptop has a mini DP port and my external monitor has a USB-C like port. The manual does say it is DP compatible.
However, all the adapters out there say they are unidirectional in the wrong direction. An example: https://www.amazon.com/Knaive-Displ...efix=mini+displayport+to+usb-c,aps,129&sr=8-4
So it looks like that would only work if my laptop was reversed as in USB C is the source and my monitor was DP.
Wiz33
However, all the adapters out there say they are unidirectional in the wrong direction. An example: https://www.amazon.com/Knaive-DisplayPort-Compatible-MacBook-Device/dp/B08399CDP3/ref=sr_1_4?crid=UB9QU70CK5NB&keywords=mini+displayport+to+usb-c&qid=1656044139&sprefix=mini+displayport+to+usb-c,aps,129&sr=8-4
Might be easier if we know which laptop and monitor you're using
rcrez
would the HDMI solution allow me to get the maximum resolution possible on the external monitor which is 3200x1800?
