laptop dual booting winxp and linux. deleted linux partitions, stuck in grub...
MATTRESS
i have almost zero linux knowledge. i used it a little for wardriving, and now I wanted to get rid of it, i didn't use it anymore.
Under winXP, i deleted the linux partitions. on my next reboot, i'm stuck on a black screen with a grub> prompt
what do i do from here? later on i'm gonna try booting off winxp cd and doing a format /mbr or fixboot to see if that works
thanks for any suggestions
of if you have a starndard ms-dos boot disk with fdisk on it than simply run fdisk /mbr
