Operaghost
- Jun 4, 2004
Didn't know if this was the right place to put this but figure its as good as any. SO.
My girlfriends laptop battery died in her Toshiba Satellite A305-S6872.
I need to order her a replacement but I want to spend as little as possible.
This is the exact replacement battery.
http://www.amazon.com/Toshiba-PA3535U-1BRS-Notebook-Battery/dp/B000PKMDEQ
My question is, would this one work?
http://www.amazon.com/Replacement-L...hiba-PA3534U-1BRS/dp/B002V17U54/ref=pd_cp_e_0
The only difference I see is the capacity, I don't know if that could potentially damage the laptop or what?
Would the cheaper battery work fine?
Thanks in advance!
Thanks in advance!
