Kryonaut grizzly paste 10c + higher whats wrong?? bait and switch ?
Discussion in 'Overclocking & Cooling' started by zoobaka, May 8, 2018.
  1. zoobaka
    zoobaka n00bie
    14
    May 8, 2018
    ste-2000 v Kryonaut [amazon]
    over 10 c higher with grizzly paste.
    Ive cleaned and swapped back and forth pastes, a few times to verify.
    What is happening?
  2. DTN107
    DTN107 [H]ardness Supreme
    4,640
    Jun 30, 2008
    I'm not trying to be a jerk today but do you honestly type like that?
    It wouldn't hurt to proof-read for a minute and post up thumbnail embedded links.
  3. doubletake
    doubletake Gawd
    513
    Apr 27, 2013
    Did you buy it straight from Amazon or from a third party vendor? Kryonaut is top tier stuff, so getting terrible performance like that means that you either got an inexplicably bad batch from the factory (unlikely), or you got swindled by a seller who bought cheap-ass, garbage-tier paste in bulk and filled Kryonaut syringes with it to resell for a profit.
    Armenius and Ocellaris like this.
  4. Ocellaris
    Ocellaris Ginger @le, an alcoholic's best friend.
    18,679
    Jan 1, 2008
    You used too much paste. And you maybe got fake Thermal Grizzly.
    Aside from that there isn’t enough information here to diagnose anything.
  5. doubletake
    doubletake Gawd
    513
    Apr 27, 2013
    Definitely, but from my limited experience with it, that stuff conducts heat well enough that even a bad OEM-style application like that still wouldn't butcher thermal performance to like what OP's getting. Unless it's actually so much that OP's inadvertently failing to apply proper mount pressure on the cooler because of the huge gap left between the IHS and coldplate.
  6. zoobaka
    zoobaka n00bie
    14
    May 8, 2018
    If you look i used same amount residu on the ihs for both paste. i will try to get a replacement. must been swindled.
  7. guitarslingerchris
    guitarslingerchris Failure is just success rounded down
    6,437
    Oct 29, 2004
    Definitely not this.
    Probably this.
    Killerxp100 and rgMekanic like this.
  8. Krenum
    Krenum [H]ardForum Junkie
    14,638
    Apr 29, 2005
    First of all, you can't get bad temps by using too much paste, but yes you did use too much, it shouldn't be spilling over the sides of your Processor into the socket housing.
    Just buy some Noctual NT-H1 Paste or some IC Diamond & be done. Both IC Diamond & Noctua are very well established brands, for good reason. No need to buy the "exotic" stuff, it doesn't do a better job, but their marketing will tell you otherwise.
    Also, what are your real world temps?
    Ocellaris likes this.
  9. zoobaka
    zoobaka n00bie
    14
    May 8, 2018
    so amazon will refund the money.. but i still have a fake grizzly mostly full crap paste..
  10. Ocellaris
    18,679
    Jan 1, 2008
    Throw it out.
  11. Putz
    Putz I have a custom title
    5,284
    Jul 8, 2002
    am i the only one who still uses AS5 in the giant ass 12g tube from like 5 years ago? couldn't count how many cpus and video cards ive used the same tube on and still half a tube left, all these new fancy ones don't see to be any better. all with margin of error
    while i dont think too much paste is causing you problem since excess gets pushed out, you have enough paste on that cpu for 6 applications :)
    vegeta535, N4CR, pendragon1 and 4 others like this.
  12. guitarslingerchris
    6,437
    Oct 29, 2004
    Arctic Silver 5 is and likely will always be my paste of choice until we get a clearly better option.
    https://www.hwcooling.net/en/the-test-of-27-thermal-compounds-part-1-en/2/
    Putz likes this.
  13. Putz
    5,284
    Jul 8, 2002
    shoudlnt need 1.35v for that speed either, unless i got lucky
    1.3v 51x100 on mine but that voltage drop will dump alot of your heat
  14. zoobaka
    zoobaka n00bie
    14
    May 8, 2018
    Update:
    An Indian Guy after a few mins of chatting said he would process a refund 3-5 days.. I called 2 days later again and it was never processed. The new guy sounds Philippine[ always somebody with an accent and hard to understand] Said the same thing he will process a instant refund this takes 3-5 days to receive.
    But it will be refunded before I send the grizzly back to amazon. I guess Normally they need to receive the stuffs first.
    Im not holding my breath. I WILL NOLONGER use Amazon. I am also waiting for resolution if there is any to Blow up feedback to that company with all the juicy details.
  15. Ocellaris
    18,679
    Jan 1, 2008
    So basically you didn’t look at who the seller was before buying the item and it’s Amazon’s fault? And apparently you dont know you can just request a refund online and get a RMA label sent to you?
  16. Krenum
    14,638
    Apr 29, 2005
  17. Krenum
    14,638
    Apr 29, 2005
    N4CR likes this.
  18. zoobaka
    zoobaka n00bie
    14
    May 8, 2018
    amazons guy didnt do what he said he would do.. so yeah.
    the company 99% positive But they never returned my email about it either.
  19. rgMekanic
    rgMekanic [H]ard|News Staff Member
    3,742
    May 13, 2013
    Definitely a bad/fake batch here. I'm running Hydronaut on my personal rig (ordered from Performance PCs) and it has been flawless.
    We use Prolimatech PK-3 on the [H] cooler test platform. It is some damn fine paste as well, albeit with a bit of a learning curve to get a good application.
  20. zoobaka
    zoobaka n00bie
    14
    May 8, 2018
    This stuff is what i used to get those lower temps in the pic
  21. Gman1979
    Gman1979 Gawd
    636
    Sep 21, 2011
    You used too much even if it's legit TG. On my 6600k, I got the best results with barely more than enough to cover the heat spreader in a "haze" of TIM. I could still read the info on the cpu through it.
    Upgrayedd and N4CR like this.
  22. zoobaka
    zoobaka n00bie
    14
    May 8, 2018
    it sqeeezes out . if you look at bothe die pics both same amount of paste maybe to much buut the cheap stuff like 15c cooler
  23. zoobaka
    zoobaka n00bie
    14
    May 8, 2018
    I got my money....chaching.. I never use amazon so the process was a bugger.
  24. Upgrayedd
    Upgrayedd Limp Gawd
    132
    May 17, 2018
    I just put some on my GPU but noticed it isn't getting even mounting pressure at first and my temps were higher as well. I reapplied a few times and tried to push on the back of my card and finally got the temps to drop a few C for me, nothing extreme 2-3C, I blame mounting pressure really in my case though.
    It also does look like you used a bit too much. I also bought mine from amazon but may buy some more from a more PC centered source to actually test myself for counterfeit.
  25. zoobaka
    zoobaka n00bie
    14
    May 8, 2018
    well i tried again using d-15s and 82c was highest in prime 95. i just put sinth thermal elixer 2 from frys on [again] and guess what 68c so either fake or bad batch
  26. Nenu
    Nenu [H]ardened
    18,298
    Apr 28, 2007
    Better quality dolls use real hair and are easier to clean after ;)
