InvisiBill
- Jan 2, 2003
I found a deal on a Kraken G10 and a Tt Water 3.0 Performer. I picked them up, planning to put them on my HD5870. I previously had an Accelero Twin Turbo Pro installed on it to quiet things down, but it has remained stock after a warranty replacement.
I have a Corsair H60 (replaced a dead ECO ALC) on my i7-920 already (part of the reason I decided to get the G10/Water 3.0). This is in my Lancool PC-K63. This case has 2x140mm fans in the front bottom for intake, 2x140mm on top for exhaust, plus a 120mm in the rear. This is where I mounted the H60, as an intake to get slightly cooler air for better CPU cooling with minimal case temp increase.
However, I ended up buying an EVGA GeForce GTX 970 SSC ACX 2.0+ (04G-P4-3975-KR) recently. The Kraken will fit on this card too, but the ACX cooler is pretty good already. Combined with the fact that none of the other fan spots are 120mm, I'm having trouble trying to figure out how to arrange this.
I was thinking I might be able to get a 120-140mm adapter and mount the second rad above the CPU, under the rear top fan. It may not reach, so I might have to install the GPU rad on the rear and move the CPU rad up there instead. If I can reach the top from the GPU, I also thought it might be better to mount both rads up top exhausting, with the rear fan just acting as a cool air intake to supply the rads. This would avoid having the two rads getting series airflow, with one intaking the other's hot exhaust - not quite as cool as direct intake from outside, but more even intake temps for both.
I guess some of this is just speculation until I can dig in and see what reaches and fits where. Until then, anyone got any suggestions for things I might not have thought of?
