HeavensCloud
Oswego, not shitty as Buffalo
- Feb 7, 2008
So none have overclocked their topsync 2710? Does anyone actually own one? Haven't been able to find a review anywhere.
I'll let you know in 7 days
I'm so tempted to buy one just to bring into work to replace the shitty 22" TN panel they provide me that hurts my eyes.
I do think work should provide decent monitors for developers, but they don't. $179 to not stare into a blurry POS every day is probably worth it to save my vision alone.
Surround is fun for all of 5 minutes before you go back to a single monitor
The topsync 2710 is back for $179 at greensum. Is this version overclockable?
I see it listed for $179 again:Looks to me like all the prices have jumped back up to $500+
More than 10 available
Now:US $179.00
Any word yet?I'll let you know in 7 days
http://www.ebay.com/itm/USED-REFURB...923?pt=LH_DefaultDomain_0&hash=item20f10b09c3
Any word yet?
I'm glad that you like the product so far, glossy 2560x1440 ftw!
these are all dead...
Damn good price. Ugly ass monitor though lol.
Just got me Shimian. The screen looks pretty good. I can't see any dead/stuck pixels. The case is more or less clean, just a few scuff marks on the stand. The only thing that bugs me is that it smells a bit like cigarette smoke. I have it next to my open window so hopefully it airs out a bit.
Is there any significant difference between the TopSync, Potalion, and Achieva models? They all seem the same to me, all $179 + CA TX.
Also, is the refurbished Yamakasi Catleap 27" IPS a better deal at $209 + CA TX, or basically the same thing?
Catleap
Not sure if refresh rate is an issue...hard to say without comparing them in person I suppose. Overclocking a monitor is a rather new concept to me. Going to have to read up on that.Someone correct me if I'm wrong but I don't think the 2703 can be overclocked, that being said its a nice piece of kit and if refresh rate isn't an issue you will love it. If refresh rate is a thing you can find a QNIX 270 for sixty dollars more (USD).
Thanks for the tip on the Samsung QNIX for not much more. It's actually only $40-$45 more for me, since all of the others are taxed. But then glossy or matte? Hard decisions that you can't reconsider after purchase.
Either way would be a step up from my Dell 24" monitors.
These all would attach to Ergotron arms, right? They are normal monitors?
So it won't be a huge hassle to attach it to the Ergotron? I thought it used a VESA mount, but may be wrong.They do have the VESA mounting holes but the stand piece that attaches to the monitor (for the shitty stand that it comes with) requires some work to remove (not required to mount to a monitor arm).
That being said I would go with a MX for this display. EDIT - An LX should work if you tension it up as I know a few people doing that).
Thanks for that.So overclocking in a nutshell is ...
However if you aren't a gamer and are purchasing this for productivity don't bother with overclocking and don't bother with the QNIX and go with the potato or lux.
I think the MX will work, but will have to measure this weekend. The LX gives a lot more option for positioning, but if the MX will be okay for me, I'll play it safe.
Thanks for that.
I need one for me where gaming isn't all that important, but video editing is, so am guessing I wouldn't even notice anything beyond 60Hz (30fps is typical max). Visual clarity and color is the same between the QNIX and others though?
And I need another that will be mainly used for gaming.
Sounds like maybe one potato/lux and one QNIX, although I need to read up on overclocking the Evolutions as I don't want to be asked to fiddle with it a lot.
Oh, Potalion is the potato, but which is the lux.. Top Sync or Achieva? (EDIT: Nevermind, just figured out one of the TopSyncs is the "TopSync Luxury" -- another is called "Orion TopSync".)
Thanks for all the advice!
I honestly would recommend you start with just one for now, these deals aren't a "limited time" thing as you can spot them once every few months. You also are going to need to get the hang of basically a total lack of monitor adjustments and all adjustments will be done through your graphics card. It isn't a huge thing but many people are thrown through a loop when they see that.
Grab a refurb that tickles your fancy and play with it for a few weeks and see how it works for you before jumping in and getting others, at worst you can use it as a spare or flip it to someone locally.
The gaming one is for someone else, but good point. Neither of us is in any hurry, so I'll order a Potato and see how it goes...if it is good enough for the gaming one, then I'll just order another for myself, if not, I'll keep it and order a QNIX for the gamer girl.
Too bad it seems every seller of these is in Cali, but even with tax, it's a shade under $200.
You also need to take into account what type of games you/her are going to be playing. Overclocking isn't needed for some types of games and these panels (QNIX) do frameskip when overclocked, so in certain games (twitch shooters/precise fighting games) it isn't optimal if you're looking for the best performance. That being said if you were looking for the best performance you wouldn't be looking at a ~300$ monitor.
I think you'll enjoy the potato and you can always slide it over and try gaming on it and see if its any better than your current setup...plus you know you'll be getting it just in time for GTA5 PCs release...
My Qnix doesn't frameskip.. You really have to get the single-input models, which are capable of overclocking without frameskipping.
