Florida Doc
- Sep 9, 2004
Do the Logitech speakers sound that much better than the Klipsch setup? Other than the controller, do the Logitech's have better features than the original Klipsch 5.1 speakers?
ramuman said:Do you mean the regular 5.1s or the 5.1 Ultras? I rarely hear people say the 5500s sound better than the Ultras.
Topher said:logitech speakers are alright for games, but at times the bass is too out of controll (not good at explaining these things, i'm no audiophile) but they lack a tweeter so their highs aren't as good and their sound isn't as tight as the klipsch
bass isn't just about being there, it has to be controlled or it doesn't sound good. a little late now but I would have gone with the klipsch
Lazy_Moron said:Yeah I have the Logitech Z640's and they also suffer from a "Bass out of control" problem. I can have it turned down all the way, and I still get the bass going crazy and being very loud.
Obi_Kwiet said:You just have to turn it down via. the Creative control panel. I'm not one of those freaks that thinks that good music = loudest bass possible.
RailGunRiz said:Creative Control Panel? I thought he owned Logitec speakers / software?
QFT. I REALLY wish Logitech would use tweeters. The sound is WAY too muddy for my liking.Topher said:but they lack a tweeter so their highs aren't as good and their sound isn't as tight as the klipsch
DaRkF0g said:QFT. I REALLY wish Logitech would use tweeters. The sound is WAY too muddy for my liking.
And I agree that their bass needs a little.... control?
Maybe non ported is the way to go.
The absolute only thing that is keeping me from getting the Klipsch's is lack of treble control. Its a dumb thing but I am picky when it comes to treble
I wish I could take the 5500's for a test run, at home. The samples in store sound like crap :\Circuitbreaker8 said:I just control the treble from the Creative CP...trust me, there are more than enough highs.
So there are other people in this world that know there are other sounds above 60hZObi_Kwiet said:You just have to turn it down via. the Creative control panel. I'm not one of those freaks that thinks that good music = loudest bass possible.
Shane said:My klipsch 5.1 died after 1 year so im weary to spend that amount of money again for the speakers they make. But hey maybe I just had bad luck dunno
I dont see one problem with having removable speaker wires. It makes it so you can cut the lenght to what you need. Granted the ones that ship with the speakers dont look too good, a thicker speaker wire really isnt that much more espensiveTopher said:also I believe they had for a while removeable wires for the z-5500s but now they're hard wired into the speakers which is a little noobish imo, people in to sound don't use the crappy cables that logitech ships it with and others that don't switch it I'm sure would like the option
oh and dark, I don't live too far from you
reread my post, I don't like them being hard wired which is another reason not to get the z-5500sDaRkF0g said:I dont see one problem with having removable speaker wires. It makes it so you can cut the lenght to what you need. Granted the ones that ship with the speakers dont look too good, a thicker speaker wire really isnt that much more espensive
Topher: Sorry to say I have NEVER heard of carlisle. PA is such a large state with so many little towns, I am surprised you have heard of the little town I live in
Oh I thought the 5500's were not hardwired. I thought they used screw type terminalsTopher said:reread my post, I don't like them being hard wired which is another reason not to get the z-5500s
I've heard of where you live so I did a mapquest (but not sure which county you live in as there was more than one)
ccotenj said:carlisle, pa, where the great jim thorpe went to indian school (king gustav: "you sir, are the greatest athlete in the world" thorpe: "thanks, king"...)...
in addition to the doylestown north of philly, there's one west of harrisburg...
american history/geography lesson over...
on topic... vat, you have anything to back up the "more klipsch speakers die in a year..." comment? i haven't seen anything definitive on that?
vat said:It seems like more Klipsch computer speakers die in a year or two.
kelbear said:The original klipsch promedia 5.1s had a design problem inside all the ones from othe early batches. There was a mis-matched resistor in there that was destined to burn out and fail after a few years. Some failed within warranty, but many did not, and an 80 dollar repair fee+ shipping was needed to fix it. In return some reported receiving the new version's subwoofer, though some did not.
The problem was caught in the later batches but not early enough for many people. I elected not to pay the repair costs. The speakers were old and had served me well enough, but it was time to move on to newer speakers.
banGerprawN said:Well, (more on-topic...) I have the Z-5500s running on an X-Mystique, and most of what is being said here is true.
The bass?
Crazy. Absolutely overpowering, unless turned right down to about 15-20% of its max. It's can also be very....sloppy, because the container IS ported, and therefore is really designed for volume and efficiency, not for the best sound. I alleviated this somewhat by opening up the box (PITA, by the way) and packing the hole and most of the free space with foam, carpet and Liquid-Nails . Sounds a hell of a lot better now, IMO.
The sats?
These are really form over function. They arent separate mids and tweeters, but rather a composite of both, which makes for some awesome sound staging, especially in games and action movies, but unfortunately detracts from their music reproduction quality due to a lack of a decent mid-range driver (noticed a huge amount in "Marilyn Manson-Rock Is Dead"). These, I have entirely replaced with a decent set of JBLs I had from another stereo, which each have 2 separate mid-range drivers and a tweeter. The sound quality goes up a huge amount when you listen to music, and if positioned and set up right, easily match the Logitechs for sound quality and staging.
The amp?
This is pretty much the only thing I really, really like about this kit. The amp is great. Produces 500w RMS at 8ohms. Plenty of power, and if you're game enough to void your warranty and open the box up (PITA, damn you Logitech!!), it has adjustable crossovers, which I changed so that frequencies below 120Hz were sent to the sub, and above was sent to the JBLs. Definitely better than the default settings.
Wiring?
The original set from logitech had hard-wired cabling on the speakers, the new one DOES NOT. Nothing more to say. The wire is mid- to high-quality, but it's only 18-gauge, which is fine for the default satellites, but i got better results by moving to 12-gauge.
Overall, I'd say it's an awesome set for a gamer or small-time movie watcher, crap for audio listeners, and perfect for the people who want to use it as part of a loud speaker system with different sats at a party, as I do now. Just use the optical-in jack on the control centre, and set it to do "Stereo x 4". Plenty of sound, plenty of bass, and it looks damn sexy...!
no idea... don't get the rational in thatPinipig523 said:How does a single driver have superior soundstaging compared to one with a dedicated tweeter and midrange?
Heh I think 500W is WAY too much for most people.Topher said:no idea... don't get the rational in that
I never turned my z-680s passed half so I don't really care if the logitechs have 30 more watts than the klipsch if the klipsch sound better (I haven't heard the z-5500s but the ultra promedia 5.1s sounded much better than my z-680s even on a display model)
A m1 fan would knowhek1 said:This is correct. Klipsch is way better quality.
