Not sure if this is the right room however
My friend just built a house... not sure why he did this but he daisy chain the cable lines down stairs...
Anyways there is one room where there are two coaxial cables and one cat 5 coming out of the wall from one wall plate...
Because of this we would like to put them all in the same wall plate however because it is daisy chained to the room next door...
I need to connect the two coaxials Holland-Electronics-Wall-Plate-Tap-Directional-Coupler and then from there go to a coaxial-F-Type-Male-Male-Adapter which then goes into a keystone f-type jack.
Is there something easier? or is this the way to go if I want to use a 2 port keystone jack?
Thank you.
Thank you.
