postcd
- Nov 24, 2016
Hello, after several recent boots of Linux Debian one of the two SSD Samsung QVO drives is not detected correctly. Sometimes help to turn off/on USB dock.
This time it not helped - "lsblk" command not shown one of the drives for a few minutes. "sudo journalctl -rg sdb" shown:
$ sudo partprobe /dev/sdb
Disk detail, fdisk -l
The drive has ZFS filesystem on it.
$ apt search zfs-dkms*
Do you have Ideas what to try please to discover the detail of the cause? Thank you
kernel: sdb: partition table beyond EOD, enabling native capacity
kernel: sdb: unable to read partition table
kernel: Dev sdb: unable to read RDB block 1
kernel: sdb: detected capacity change from 15628053168 to 1
journal:Error: Can't have a partition outside the disk!
-> in same second as i ran partprobe command above, it detected capacity and the drive appear in "lsblk" output. (Update: i confirm that it happens repeatedly that i must run this command in order drive being initialized/recognized )Error probing device: Error sending ATA command IDENTIFY DEVICE to '/dev/sdb': Unexpected sense data returned
0000: 70 00 01 00 00 00 00 0a 00 00 00 00 00 1d 00 00 p...............
0010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
(g-io-error-quark, 0)
kernel: sdb: detected capacity change from 1 to 15628053168
spl-dkms/stable,stable 2.0.3-9 all
Solaris Porting Layer kernel modules for Linux (dummy)
zfs-dkms/bullseye-backports,bullseye-backports,now 2.1.5-1~bpo11+1 all [installed]
OpenZFS filesystem kernel modules for Linux
