Kensington Wifi Finder $4.99
S_G
The code "silverpot" seems to work with the Wifi Finder. I have no idea if they'll honor it after checkout, but it should work. It doesn't work on all items, just some, which is weird, because I think it was made for AS5 (hence "silver" pot) 3.5 gram (doesn't work on 12 gram).
Takes off $7 from your order. So you still have $1 to waste!
Least
if you don't use it with item, you can use the extra money towards shipping.
droctogon187
The code does not seem to work once you get through the check out process:
Hardware Cooling said:
Products (Edit)
1 x Kensington WiFi Finder $4.99
-$7 Silver -$0.00
Sub-Total: $4.99
Flat Rate (Best Way): $6.95
Total: $11.94
S_G
Well you may as well grab some AS5 for free if you order the Wifi Finder.
Gilthanis
[H]ard|DCer of the Year - 2014
TigerDirect also have these at the same cost after the rebate. http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=624785&CatId=1817
I have had one of these for a year and I would give it a 6.5 out of 10. It seems slow to detect the networks. Standing next to my router, it doesn't always pick it up for a few minutes. Then other times, (while in my truck) it will pick them up just going by. I think it has to do with the feature in it that searches for other networks for stronger strengths.
Least
time for a new router :D
haha, just kidding.
Gilthanis
Ummmm...no don't tell me.....I guess 6? (Yes that is sarcasm.)
