PAo_ReVoLT
- Apr 4, 2008
it start since friday night i got BSOD "iqrl_not_less_or_equal" while booting into window after that i try various combination in bios, swap RAM, swap GPU after 20 times i got lucky to boot in to window once. i back up all my work files to my server over the LAN.
after that i decide to reinstall window, when i put window DVD while it was loading to setup i keep getting BSOD "iqrl_not_less_or_equal" same as before sometimes it went thru setup but after 1st installing finished it will require restart to continue to window setup i will get BSOD on the 2nd phase so there is almost no way to even install the window.
i try to google around most people say it is about bad RAM but i ran memtest passed 24 hrs, i have many ram to tried only 2 things i haven't change yet are MOBO and CPU
any idea?
thanks ^^
spec:
what i have tried is
- reset/update bios to newest version
- 8 different stick ram | 1 at a time | different slot
- 3 HDD (all sata)
- 6 GPU (both nvidia/ati)
- 2 window DVD (both x64 OEM and retail)
the rest are
MOBO: asus striker 2 formula
CPU: qx9650 non overclock
PSU: pc power cooling 860w
any idea?
thanks ^^
spec:
- 3 HDD (all sata)
the rest are
