AnubisReturn
- Dec 19, 2017
So I just picked up a Sony KD43X720E from Costco to use as a monitor and everything looks great, except in certain warm grays, there are flickering green pixels arranged in a grid like pattern. The grid is consistent and across the whole display and always the same pixels.
It's hard to capture a photo as they flicker at different rates, while some remain solid green. I've adjusted the contrast a bit and circled the pixels in the photo below.
My GTX 970 is the only source I can test that can output 4k 4:4:4, and this is the only 4k display I can test it on that has HDR, another older 4k TV works properly with this card.
In the nvidia control panel I have it set to 60hz, RGB, full dynamic range. Lowering any one of these settings the issue goes away. I've tested multiple cables and drivers and different scene modes and settings on the tv, still with the same issue
I can consistently reproduce this flickering green pixel grid pattern. I pulled up photoshop fullscreen and adjusted a gray slider until I can see the flickering.
I plan on picking up a UN40MU6290 on boxing day to compare as I was deciding between one of these 2 to keep, I can't narrow down if its my video card or the display until then. Does anyone know what the issue may be or what it's called? I haven't had much luck searching or what keywords to use
