For anyone watercooling thier neo2, what chipset cooler are you using? my asetek waterchill chipset cooler will not fit. if no waterblocks fit what aftermarket cooling are you using? ive heard the vantec iceberg works, but is there anything better is is that the best?
Also a side question, but the top of the processor (.9 amd64 3000)is just a heatspreader correct? Im asking because im going to be reusing my DD RBX waterblock, but it misses covering the whole top of the processor by about 1/16 of an inch on the long sides. If the top is a heat spreader it will be fine, but if not ill have to use my old stock waterchill unit (or get a different one)
