K.15.08.0013 HP code anyone running it?
Discussion in 'Networking & Security' started by haunter, Dec 14, 2012.
  1. haunter
    haunter [H]ard|Gawd
    1,883
    Jul 20, 2011
    I need to update code on my 5400 class HP Procurve's
    We think we have ID'd that as what we want to move to, I was curious if anyone else has a large # of 5400 and 3500's out in the world on that code, or on another code because they ID'd this as bad
  2. timberdoodle
    timberdoodle Gawd
    878
    Sep 22, 2008
    I haven't updated our firmware but we are on K.15.06.0008 for all two of them.
  3. feffrey
    feffrey Gawd
    593
    Oct 26, 2010
    We have a 3 5400s and and a couple of 3500s. The 5400s are on K.15.07.0012 and the 3500s are on K.15.07.0008 I think.
    Went to K.15.07.0012 due to a issue with K.15.07.0008 and directed broadcast not working. Other than that we have not had any issues with K.15.07.0012.
  4. green91
    green91 Limp Gawd
    398
    Sep 2, 2012
    Im running 50+ 5406zl chassis on this code.
  5. haunter
    haunter [H]ard|Gawd
    1,883
    Jul 20, 2011
    You should upgrade
    there is a problem with K15.06.-0014 where they can hang on reboot
    (also exists K15.07.0002-0007)
    maybe thats not a huge issue for you, but I am pretty geo-diverse(large college campus) so not coming up after a reboot is a huge problem
    cool thanks for the info man
  6. haunter
    haunter [H]ard|Gawd
    1,883
    Jul 20, 2011
    I'm guessing no serious issues?
    Are you routing on any of them?
  7. green91
    green91 Limp Gawd
    398
    Sep 2, 2012
    I don't route on any HP equipment anymore, primarily lots of vlans, lags, etc. I only use 5406zl as access layer switches. Upgraded to this firmware to fix a pxe boot bug on an older firmware.
  8. timberdoodle
    timberdoodle Gawd
    878
    Sep 22, 2008
    I will thanks!
  9. haunter
    haunter [H]ard|Gawd
    1,883
    Jul 20, 2011
    we are starting too. but only because we have some small buildings, and dont want to drop a 8000 dollar router in front of a half full 5406 chasis, when all we do is run OSPF and a handfull of vlans in those places. it saves us a fair amount of money
    we actually run a small DC on a pair of them in VRRF with alot of them full up on 10gig
    np :)
    I discovered that on Friday, we actually are on that version on everyone we have that has a 10gb card in it.
    I started to investigate because we run some IPv6 here and there is a big RA vuln out now, and we arent on a code train that has RA guard.
    I checked that version first since we run it elsewhere and got the notification that I need to upgrade!!
