Well you won't be dissapointed. I did a couple of mods, I removed the felt ring to clear up the mids and hi's, not necessary and not a major change. The one that I appreciated was stuffing strips of light density foam under the earpads to move them out, it changed the sound a bit, almost seemed to add soundstage and made them more comfy for longer...I can wear them as long as I want where-as before I had to take them off after a couple 2-3 hours. Not a bad thing for a $35 headphone, as good as they sound, the only complaint I have is not knowing about them sooner!
I still cannot decide between RX700 and RX900 (about ~$25 diff)... please help
I would be using cans with PC gaming (I like good bass) and onboard audio (VIA 1708B). Until recent I was using el cheapo Sony gym headphones... For the last 2 nights I was using cans from work el cheapo Panny RP-HT455 and I'm really start liking the closed cans concept. I belive either JVC set would be an upgrade over Panny set, so I should be more than happy with either purchase. The only missing feautre would be inline volume control. Since I'm planning to keep them for the next little while I don't want to skim $25 difference... However Ihave a tiny problem with my mATX mobo and 6950 whcih is blocking all pci slots and all ll I have is PCI x1 slot... which limits me with audio card selection. Therefore I might be stack with onboard audio... Perhasps Fiio amp would help? For more specs please see my sig...
So based on the above which cans would be better for me... ?
TIA
Thanks for your prompt feedback...
I'm not an expert but will my onboard audio be good enough to drive RX900? I believe its input impedance is at 64 Ohms, and RX700's at 48 Ohms, where my current Panny 455 are at 24 Ohms. So does this mean RX900 requires 3 times and RX700 2 times more than my current cans? Will the volume levels be cut by 3x and 2x respectively? I do apologize if this is stupid question...
I would hate the cans to be "wasted" due to my onboard audio not providing enough juice...
I can drive mine through my front panel audio connector, so I doubt you'll have problems.
900 is like having bigger speakers in a larger room than the 700. You will want to look up the mods to improve them a bit more. Very easy to do but not vital.
I have a set of these headphones + a Xonar DG coming in tomorrow (just wanted the built in headphone amp)
Once they get here I am just going to have them play junk for a few hours to break in before I toss them on.
That is probably the best budget headphone setup going. For speakers, go with the same sound card and the partsexpress t-amp + bookshelves deal for $58.
