Lord of Shadows
- Mar 9, 2004
So I finally pulled the trigger on my next gaming PC, my current one was built like Oct 2011, which is a pretty good run compared to how it use to go. It started with buying the case at work, then the PSU at work, to complete mind disconnected impulse buying when I got home.
Here's the damage so far:
Amazon
$211.99 Gigabyte GA-AX370-Gaming K7
$434.99 AMD Ryzen 7 1800X
Newegg
$329.99 SAMSUNG 960 PRO M.2 512GB NVMe
$186.99 G.Skill FlareX 16GB DDR4 3200
$699.99 Gigabyte GTX 1080 TI (reference design)
$185.98 SILVERSTONE Strider SST-ST80F-TI 800W
$179.99 Corsair 570X RGB
So I'm going to get a lot of boxes soon, but to put them together I still think I need an air cooler (feel free to make recommendations)
And I'll also have to figure out how to install windows from a USB stick as I wont have a disc drive
(I did the windows 7 to windows 10 free upgrade thing, not too sure how that's suppose to work with a new install)
Edit: Starting to look at the corsair h100i, I'd prefer the reliability of an air cooler, but they seem to make this pretty hassle free, anyone have any ideas on leaking / refilling? Supposedly it doesn't need refilling, but my custom Tygon tubing loop definitely evaporated through the tubes
Edit2: Figured I'd better man up and get the corsair cooler, has to be easier than my old custom loop, and should look cool, might even haul this rig to quakecon this year (have to get the quakecon barcode on there to officially sanction it)
-- I did look at the noctua, but man that's expensive for air cooling, figured for the price I can have a quiet water loop vs the tornado it may end up being under load (Although, now that I see that it might actually be quieter, I'm having second thoughts)
Amazon
Newegg
