Sounds like you've got it about right. Nothings you've said seems out of place.
I don't think there are many monitors that, when everything is balanced out, will be able to be awesome at showing 254 on a 255 background, or at showing 1 on a 0 background. Losing a little bit of information on the far ends isn't that bad. On the RGB, I try to lose no more than 2 or 3 divisions on the high end, and 1 or 0 on the low and. I really had a hard time getting the westy to not oversaturate and blend in the top range of colors so much.
And I'm am also a little suspicious they went to TN on the Westinghouse. 700:1 contrast is not cool, especially when that's not what's advertised.
[RCKY] Thor;1031540744 said:Play with the brightness/contrast and if you have to gamma/brightness/contrast in the driver and you can fix that. See the posts above with links to calibration pages.
Yep. My upper- and lower-range contrast seems fine. I don't have a (color) oversaturated top end, as far as I can tell, although if you've got a test chart, I'd be happy to compare.
My OSD shows version 1.0. Yours?
Also, I'm curious as to what options the flower-menu (initial for me) gives others. I get only [brightness/contrast/sharpness], yet my manual lists, additionally, [Color, Hue, DLC (dynamic luminescence control), and backlight.] Note: I'm using DVI->HDMI, which shouldn't mess it up, but who knows
AFAIK, those extra settings you don't see are used only for analog inputs. If you use component or D sub, those options. should show up. I don't think you need them for digtal input though.
Any my OSD was 1.1, not 1.0.......... Who knows if that means much though
Input lag results relative to CRT:
37 ms so just over 2 frames. (Note - quick test, only ~20 samples, camera at 1/500 due to CRT light-levels. Someone else should also do it.)
No wonder I noticed it.
Edit: By now I'm pretty sure it's not a TN, unless they've somehow gotten rid of the inversion/black fade when viewed from below. It fades just like an MVA, so now the question is simply why is this MVA panel 160/170 viewing angles/5ms/700:1 instead of 176 viewing angles/8ms/1000:1.
Got mine...
input lag... I WANT TO THROW THIS THING OUT THE WINDOW.
I wasn't even able to right click my desktop and change resolution without saying to me self "oh god". If this is 30ms then I can't even imagine how people use LCDs with 50ms+ of lag. Maybe it's worse over VGA than HDMI, or at least I can hope... DVI>HDMI cable should be here friday and we'll see.
What brightness/contrast is everyone set at? I can't find a happy medium.
Got mine...
WUXGA... kicks ass
24"... huge (hope it seems this big for at least another week)
TN -> MVA transition... looks a lot better
You might want to try defragging your HDD....
actually i think i might be getting some input lag too...
it kind of feels like theres mouse accelleration on but i checked my logitech settings and its definately off.. i dont know if this is input lag or not but mouse movement just felt more responsive on my viewsonic vx2025wm
who knows it might just be my imagination- and the dvi-hdmi cable might be different
It sorta feels like it's not as bad via hdmi, but the lag is still there and it's still pissing me off.
Another thing is, blacks (like the black screen with default windows screen saver) are nowhere near as black as my TN panel. What gives?
