Makeroflostsouls
- Jun 4, 2008
So I moved my main rig into my rack. Its now hooked up to my dual HDMI out Yamaha. I can game up stairs on my 50 or down stairs on 120inch dlp projector. There is just nothing that compares to a 120inch display. Makes you really feel like your in the game. I have played on triple monitor setups, 30inch 2560x1600 and 120hz display. I'll take the 120 over all of them. Now 120hz 120inch would be golden . But the dlp is extremely smooth almost 0 (17ms) input lag and no ghosting. Has a very CRT feel to it (also use to have a Sony 24 inch CRT). For the money if you have the room I would recommend it to any one. Can pick up an Optoma like it have for 799 now days and make you a screen for little over 150. The bulbs are also cheap for 140 for 5-6k hours. I think projection is a great option for PC gamers now days.
