Ive just finished my new build, i asked awhile back for some help choosing between amd 64 3000+ and 3200+ socket 939. I went with the 3200+ and im just wondering what temp it should be at. Its first start up was about an hour ago no os loaded. I left it running for about an hour just to make sure all was ok and apart from the front panel leds not working and an error on the post screen (more about that in a minute) all seems ok. I had the bios on screen showing cpu temp and it was 40c to 42c is this ok, its got stock amd hsf installed and case (jeantech butterfly 2) has 1 80 mil fan at front and 1 at rear. Ive done the wiring pretty neat so theres no obstruction to air flow. The case also has a cicular vent left side buttom rear and another vent further up which has a blue duct which looks as though its intended for one of those hot running intel critters. Here is the error im getting reported on post screen
PXE-E61 media test failure, check cable
PXE-MCF: exiting pxe rom
Is it anything to worry over or should i see what happens after ive loaded os and drivers. Here,s the spec, not the fastest but a big improvement over its predecessor
Case Jeantech butterfly 2
amd 64 3200+ venice
1gb 2x 512mb corsair value select
120gb 7200 sata hard drive
msi k8n neo 2 platinum
amd 64 3200+ venice
