Just a little bit thinner. (CM World Series 2017) ZenModz
Discussion in 'Worklogs' started by Zenator, Mar 13, 2017.
  1. Zenator
    Zenator Limp Gawd
    131
    Jun 21, 2015
    [​IMG]
    Hello Again :)
    I had not planed on doing a second build for the world series but I still have time for something small. I have been thinking about doing a small form build for some time
    and i've been wanting to do a white build as well, so for this build im looking at doing a build in white and making it slim.
    I Will be using a Master Case Maker 5 and a Cosmos SE
    [​IMG]
    [​IMG]
    De-construccion have begun, lots of cutting still to go to get that "SLIM" look and the MIG waiting to put it all back together again.
    [​IMG]
    Quick layout of parts from both cases.
    [​IMG]
    And a way to put it all back together again, Oh what fun this will be!
    Some steel may be injured in this process :thumb:
    [​IMG]
    So Far what i'm doing is im trying to reuse as many parts as I can from both cases. The MoBo tray has been centered in the case to have even room on both sides,
    The back side being for the cooling and cabling, Giving me 80mm at the back and 80mm on the MoBo side and a 160mm all up. More then enough space to get things done.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Here is a update on some of my older build pic as i have not posted here for some time :(
    Hope you all like them.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Might as well add my newest builds as well that some of you may not have seen.
    First one is DOOM
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Power Cell Scratch build.
    [​IMG]
    Gears of War 4.
    [​IMG]
    [​IMG]
    If you would like tosee more pic's
    they can be seen in my FB page.
    https://www.facebook.com/ZenMods/?ref=bookmarks
    Thanks for Stopping by.
    Nanogrip likes this.
  2. Zenator
    Zenator Limp Gawd
    131
    Jun 21, 2015
    Update on the Thinner build, Case frame is now reshaped. The back of the case now has room for 2x360 rads for the cooling the GPU & CPU. And in side the MaterWatt Maker 1200 PSU. Still lots more to come and still lots more to do.
    [​IMG]
    [​IMG]
    [​IMG]
  3. Zenator
    Zenator Limp Gawd
    131
    Jun 21, 2015
    Some of the very COOL hardware going into the Thinner case.
    MAXIMUS VIII HERO ALPHA MoBo W/block, From Bitspower.
    [​IMG]
    ASUS STRIX 980ti And Bitspower RBG W/Block.
    [​IMG]
    [​IMG]
  4. Zenator
    Zenator Limp Gawd
    131
    Jun 21, 2015
    Time again to show some pic's.
    From one case to the next I have used the rear GPU mount from the Cosmos SE cut it out reshaped it to fit in the top of the frame to hold the GPU in place. Plus one new clear and black printed GPU logo, For some back light RBG.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  5. Zenator
    Zenator Limp Gawd
    131
    Jun 21, 2015
    A bit more to show.
    [​IMG]
    [​IMG]
    [​IMG]
    Thinner with a theme.
    [​IMG]
    [​IMG]
    [​IMG]
    More soon.
  6. Zenator
    Zenator Limp Gawd
    131
    Jun 21, 2015
    Outer plastic covers now done and a place for the CM badge.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  7. Zenator
    Zenator Limp Gawd
    131
    Jun 21, 2015
    Switchers fitted for a new clean look.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    spugm1r3 and Derf like this.
  8. Zenator
    Zenator Limp Gawd
    131
    Jun 21, 2015
    Hi, The color I picked for the build is Harlequin. That will have the same colors as the guardians of the galaxy theme. It still needs to be clear coated as well.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Krenum and Derf like this.
  9. Krenum
    Krenum [H]ardForum Junkie
    12,383
    Apr 29, 2005
    Man, that's pretty awesome! CM take note! I currently have the Master Case Pro 5 & I'm really jealous! Really like the legs for it.
