jump to 64bit - a couple of questions
wizzackr
i am currently putting together my opteron system and would really like to give xp 64 a spin - mainly because softimage XSI is now fully 64bit. problem is: i am currently using AVG as a free anti-virus program along with zonealarm as a firewall. both are not 64bit ready, according to their webpages. what other free programs could i use to substitute these? any idea? getting a 64 OS and buy a virusscanner / firewall is over budget, though...
Actually AVG 7.1 is now compatible with XP64, I am using it right now with the firewall option. The firewall runs in 32-bit mode though.
Linky
Good luck!
daemon tools now supports x64...which is good for alot of people.
Linky
Good luck!
but only the pro version, not the free one AFAIK (see here) :confused:
I know AVAST supports 64bit in their free home edition, but that is one crappy virus scanner if i remember correctly...
thanks a lot for the input so far, guys
ah well, I'll get a copy of NOD32 and be done with it. AFAIK that is a pretty good scanner, right? How about Zonealarm - can I still use the 32bit version under XP64?
I'm using Avast here. I bought the Pro version and I like it a lot, especially compared to McAfee or Nortons!
For firewall I have a router and Windows firewall.
I'm running NOD32 at the moment and I got to say it's the best antivirus program so far. AVG, Norton, McAfee and Panda was not as good imo. I especially like the AMON and IMON scanner components.
I've used Avast and AVG (trial) and I really can't choose one over the other, but since Avast is free I'll keep it for now
NOD32 is pretty nice.
Zonealarm is just a resource hog. I use a router, but i would think windows firewall would be a fine replacement for zonealarm.
