josephclemente
- Dec 31, 2006
Case: SilverStone SG05
Fan: Scythe Gentle Typhoon AP-13 1150 RPM 120mm, used as front exhaust
PSU: Seasonic X-460 Fanless
Motherboard: ASRock Z77E-ITX
CPU: Intel Xeon E3-1230 V2
CPU cooler: Antec Kuhler H2O 620
RAM: Samsung 8GB 30nm 1.35V DDR3 1600
GPU: PowerColor Go! Green AX7750
SSD: Samsung 830 Series 256GB
I replaced the original restrictive front hex grill with a much more open hex grill (ModRight ModMesh).
I modified this case to accommodate a full size ATX modular power supply.
A sheet of aluminum was cut to hold the SSD drive at the side of the case.
I measured AC power consumption with a Kill A Watt.
Power Consumption:
IDLE: 39W
Prime95: 98W
Prime95 + Furmark: 138W
Prime95 was set to Torture Test In-place large FFTs.
Power Consumption:
IDLE: 39W
Prime95: 98W
