Join The Dark Side, Build An Intel Rig! (Intel Owners Post Your Rig Here!)
dirtypop
Pentium D 820 @ 3080MHz
1GB DDR2 @ 733MHz
Radeon X850XT-PE
Raptor 36.7GB
Asus P5LD2-VM
in an Aspire X-QPack
[edited to add] running XP x64 Pro
Duke3d87
I was blinded when i built my pc so it's AMD based
my dad's PC is average
2.7 Celeron
768 MB RAM
Thermaltake Tower112
160 GB Seagate HD
Thermaltake PurePower 410 watt PSU
Mad_Gamer
Intel 3.73ghz 1033mhz Extreme Edition
Intel 925XE motherboards
4x512mb Micron DDR2@667
2x120gb Seagate 7200.7 Raid-1
Radeon x800 PE (I will upgrade!)
Lian-Li V1200-B
Dell 2005FPW
mrtheshaggy
P4c 2.4 @ 3.3 (275)
Thermalright sp94 w/ 80mm smart fan II
2x512 pc4000 ocz 2.5-4-4-7 (275)
evga 6800gt 256mb
Thought about upgrading but this system still kicks ass.
m0unds
P4 2.4GHz @ 2.8 Northwood
ThermalRight AX-478 + Vantec Tornado (yuck)
2GB DDR333 Kingston
2 WD 120GB 8MB SE 7200 RPM HDD -- Striped
Visiontek X850XTPE (I think the CPU's a bottleneck for this thing..what do you think?)
I'm going to upgrade the CPU and RAM soon, and give the northwood to my girlfriend, as i'm building a box for her.. (she's using a K6-2 500 right now..:D)
S
SirKenin
Guest
Intel rigs eh? Ok, I'll bite.
Main workstation
P4 2.8e
1GB OCZ EL PC3500 DDR
Asus P4C800-e Deluxe
Mutant Mods Reactor PS
Asus AX800 Pro
WD Raptor 74GB HDD
Maxtor D740x 40GB HDD
Pioneer 16xDVD
LG DVD+/-RW
Sound Blaster Audigy 2
Chen Ming windowed case
coloured fans, neon and wrappings throughout.
Dell 21" PF Trinitron
Samsung SyncMaster 912N TFT
XP Pro
Backup workstation
P4 2.4c
1GB Crucial PC3200 DDR
Asus P4PE
HEC 350W
ATi Radeon 9800 Pro
Maxtor D740X 40GB HDD
Pioneer 16x DVD
Sound Blaster Live! 5.1
Antec case
Dell 21" Trinitron
XP Pro
Third workstation
Dell Dimension 3000
P4 2.8GHz
512MB DDR
unknown mobo with everything built on
Seagate 80GB HDD
LG CDRW
Dell 17" monitor
XP Home
Server
Celeron 2.0 GHz
768 MB DDR
WD SE 40GB
ATi Radeon 9700 Pro
ECS mainboard (ugh)
windowed case with coloured fans throughout
onboard LAN and 3com LAN
TTX 17" monitor
Windows 2000 Advanced Server
File Server
Dual P3-850 MHz
460W PS, but can't remember the brand
Asus P2B-DS
512MB RAM
ATi Radeon 7000
WD 20GB
IDE controller card to run:
Maxtor D740x 40GB
Maxtor ? 40GB
CD and case are nothing fancy, but they work.
Dlink and SOHO NIC
KDS 15" monitor
Firewall
P2-450MHz
256 MB RAM
Quantum Fireball 6.4GB
dual NICs, but I can't remember what they are off the top of my head.
Some ATi video card, can't remember.
CD, case and PS are nothing special, but what do you really need for a firewall computer anyways?
Smoothwall Firewall (linux)
I also have a HP Duron 900, Dell P3-866, P3-450 mutt, Athlon 1400+ and a P2-333 system sitting here.
BM98MaSTeR
Intel... hmm
HTPC
P-D 3.0 MhZ
Intel 945G
1GB OCZ Gold DD2 533mhz CL 3-3-3-8
Gigabit LAN
SoundBlaster Live! 24-bit
Intel Graphics Media Accelerator 950
Sony DRU800A
74GB WD Raptor HDD w/ TCQ
160GB Seagate Barracuda 7200.7 w/ NCQ
Dillusion
Heres my new watercooled setup, should be up and running by next friday with a nice 5ghz OC :) -
P4 570J ES
Abit AL8-V 945P
ASUS X800XL
2x512 GEIL DDR2-533 (Does DDR2-700)
Enermax Coolergiant 480w PSU
Lian Li PC-7B Plus
+ The usual suspects...
As for the WCing:
PolarFLO TT CPU 3/8"
PolarFLO TT VGA 3/8"
DangerDen Low Profile 3/8" Pump
Black Ice Pro 120MM Rad 3/8"
Typhoon Red UV 3.5" Res
8' PrimoFLEX Red UV Tubing
MCT-5 Fluid
GVX
If you can get it to 5Ghz, then it will destroy even an FX-57 in gaming. You should do it and then go start a thread in the AMD subforum bragging that your "measly pentium" will dethrone an FX-57.
chrisf6969
chrisf6969 said:
Ok, just configured a system for a friend:
ASUS P5GD2-X Socket T (LGA 775) Intel 915P ATX $106.00
MSI Geforce 6200TC PCIe x16 Video Card --------------- $58.00
Pentium 4 530J Prescott 800MHz FSB LGA 775 ------ $173.99
PNY Optima 512MB (2 x 256MB) DDR2 533 -------------- $47.91
WD Caviar SE 80GB 7200 RPM Serial ATA150 --------- $54.00
56Kbps Internal Fax Modem(NetoDragon) ------------------- $6.30 (56gay)
LITE-ON Black IDE DVD Burner Model SOHW-1693S - $48.00
Microsoft Windows XP HOME Edition w SP2 OEM ---- $88.95
Thermaltake Soprano Black Case 430W PSU ------------ $85.00
shipping ------------------------------------------------------------------ $34.78
TOTAL = $706.68
Ok so I built this rig with my friend Tuesday afternoon/night. Installed all the software and OC'd it. At 3.3Ghz, default voltage, it was hitting 68C (with Prime95), so I backed it down to 3.2 and it was at about 64C loaded. I was a little disappointed with the OC, and was thinking about dropping the multi to get a higher FSB OC. But we were kinda in a rush.
Anyway, I was thinking about it today. I should have replaced the crappy little TIM that came with the stock HSF with some good thermal paste which I had at my office (not home). Anyway, I'm going to stop by his house one day this week and try reseating the HSF with some nice thermal paste and check for a better OC.
P.S. Its an E0 stepping. I'm sure its got a lot more headroom in it and it just needs better cooling.
bimmer01
I switched from A64 to Intel recently. LOL.
A64 had issues with physical memory controller where it would reboot every hr and i would get the BSOD with a memory controller error. GAVE UP on A64.
Now running INTEL and SMOOTH AND STABLE~!!!!
CM Stacker: (Gaming)
P4 3.6 560J LGA 775 w/ XP-90 + 92mm Panaflo
2x 512 Samsung DDR PC3200
Asus P5DGC Deluxe
PNY Geforce 6600GT PCI-E
Audigy 2
1x 74GB Raptor SATA
Samsung DVD/CDRW combo
Enermax 485W PSU
Skyhawk: (Server)
P4 2.4C w/ Zalman 7000cu
4x 512 Samsung DDR PC2700
Intel D865PERL
Geforce 2 MX200
Onboard sound, NIC
1x 40GB WD IDE
1x 120GB WD IDE
1x 400GB Hitachi SATA
Antec SL350W
omniviper
FIne I'll bite too
P4 3.4 EE ES with xp-120 and a panaflo 120 mm
4 x 512 mb OCZ pc3700 EB
MSI NEO2 -PFISR
Cooler master stacker
Audigy 2 ZS plat
2 200 gb seagate 7200 rpm drives
2 74gb raptors in raid 0 array
2 nec 2500 dvd burners
bfg 6800 ultra
Logitech Z-680
Antec Tru 550
Burner27
bigr5026 said:
my amd side is ready to flame but ill restrain myself
Were you talking? I thought I heard someone fart................... :D
Decibel
Shuttle SB65G2
3.2c @ 3.6ghz
1gig Corsair XMS
x800 Pro VIVO w/ 16 pipes @ 540/590
74 gig Raptor
250 gig 7k250
2x 120 gig USB HDs
Audigy2 ZS
Lite-On 48x/24x/48x/16x Combo Drive
High gain wireless antenna
Big ass Rubbermaid box w/ a 2x120 radiator, a pump and an Enermax PSU
Kinda killed the portability of my XPC until I get my custom case built...
-dB
Burner27
bimmer01 said:
post your rig Burner27.
Show me your $$ rig.
Fine, here it is.....this is an older picture that doesn't have some of the upgrades in my sig. The board in the picture is an Asus P5AD2E-Premium Wifi/Ed, Audigy 2 ZS, stock HSF is being used and there is only 1GB of ram. My sig has my current setup and I am using an XP90c/Panaflo combo on my CPU.
Mine is in my sig. Been using Intel rigs ever since I got into computers. Finally taking the plunge to AMD though, Intel just isn't appealing to me anymore...*sigh*.
Worminater
i have an old dell optiplex gx1 i use as a linux box.
450mhz of p3 powa; 10gb hd; onboard everything.
thing as served me well:)q
*foo
Here's my current workstation. I got rid of my dual box to get rid of excess noise and heat. With this new box, I was going for quiet and I've achieved it. The cabling needs work, but I'm content with it for now. The vid card and CPU are watercooled, so the only fans in the box are a 120MM Vantec stealth on the radiator, two 80mm Vantec fans cooling the HDDs and the PSU fan. The Intel board has great fan control, so they're all nearly inaudible. My HDDs drown them out.
Supermicro SC472 case
Intel D955XBK motherboard
Pentium XE 840
2GB DDR2-667
X850XT PE
Intel SRCU42E PCIe U320 RAID card
2 x 73GB Fujitsu MAS 15k U320 in Raid-0
4 x 136GB Fujitsu MAP 10k U320 in Raid-5
1 x 250GB Hitachi SATA
Generic BT878 TV tuner
Lite-On DVDR drive
Antec 550W EPS12V PSU
Dual Dell 1800FP monitors
Windows XP Professional
Click on the pics for the Great Big versions.
cnick79
P4 3.4ghz 512kb cache @3.8ghz (224mhzx17) 1.675v
Corsair TWINX1024-3200C2PT 1GB DDR400 XMS3200 DC 3-3-3-8 (replacing with OCZ Plats 2x1gb)
Abit IC7-G MaxII
(2) Raptor 74Gb RAID 0 & WD 120GB
eVGA Geforce 6800 Ultra @470/1.195ghz 1.6v
Audigy 2 ZS, Lite-on DVD-RW/R
Lian-Li PC6070B w/Dust - acts as noise dampening and insulation & Spiders - to keep out theives trying to steal my parts
Antec TruePower 550w
Dell 2405 LCD
Custom Water Cooled
Upcoming File Server:
Pentium D 2.8ghz
2- 250gb Maxtor Maxline 3's 16mb Cache RAID 1
Corsair TWINX1024-3200C2PT 1GB 2x512mb
and other parts to be named later
Digital Viper-X-
P4 3.0C 800FSB 512K
ASUS P4P800SE
1GB Kingston Value Ram 2x512
ATI 9600Pro 256MB
80GB WD SATA
160GB Maxtor SATA
200GB Maxtor SATA
250GB WD SAta
Copey
3.2e @ 3.6 cooled by a Titan Vanessa L-Type
2x512mb Generic Ram
Gigabyte 8S661FXMP - Soon will be upgrading to a DFI LANPARTY PRO 875B REV B
WD 120Gb
WS 40Gb
Samsung DVD-ROM
Song DVD Burner
HIS Excalibur 9800Pro ICEQ Platium
Some generic case - soon will upgrading to a SIlverstone TJ06
rucknraul
Asus P4C-800-E Deluxe
Intel P4E 3.0Ghz
Zalman CNPS 7000 Al-CU
kingston Value RAM 2 Gigs(4x512mb)
Club 3d ATI RADEON 9600 XT
2xWD 36.7g RAPTOR 10000 rpm SATA in RAID 0 w/Windows XP Pro SP2
Maxtor 250g SATA 16mb cache
Hitachi Deskstar 120g ide
Yesico FL-480 480W Fanless PSU
NEC 3540 DVD writer
Cooler Master Aerogate 1
All enclosed in a Cooler Master Cavalier CAV-T30 case and viewed through a 20" Viewsonic LCD display.
My setup is in constant mutation so...
Intel Pentium 4 530 @ 3.2GHz
1GB (512MB x 2) DDR400
WD 250GB SATA
x300 :( 6600GT blew up, being RMA'd
Antec True 480w
Logitech wireless mouse/keyboard combo
Sony 17in. LCD
S
SirKenin
Guest
Why the hell do people list what they don't have? I can't figure that one out.
S
SirKenin
Guest
NitrouseXpress60 said:
your refering to my 6600GT? i have had it for weeks until it started on fire and should be arriving shortly. idc cuz i will still have a 6600GT and paid for my 6600GT ran 3d mark 05 with my 6600GT so therefore i have a 6600GT
No actually, I missed that post.
