John Carmack Responds to the ATI Humas tweek
Status
Not open for further replies.
burningrave101
Moofasa~ said:
Show me images where it lowers quality...
This is a known fact from people that have ATI cards and have done testing. I've seen it talked about quite a few times in forum threads.
If you dont believe me then do some testing for yourself. Take Far Cry for example and benchmark using in-game AF and then benchmark using CP AF.
R1ckCa1n said:
Do you have problems understanding what you read? If you would take your hat off and read the B3D thread, you will soon understand it comes down to the hardware. ATI's cards where not optomized for the way Doom3 renders. The NV40 was made to run best on Doom3, which it does, where ATI is made to run all games consistant. What those guys at B3D figured out is how to tweak the shader to run it with more math, ATI's strong point. It's pretty much as simple as that. Once they figure out how to make the shaders mathmatically correct, it will render just as the artist entended it too.
Please don't make this into more than it really is like some people.
I think you have problems understanding what i post. What i just said holds true for ALL games and ATI hardware. I wasn't talking about DOOM 3.
You'll get a little higher AF quality through in-game Anisotropic Filtering but the performance will be slightly lower because it has been optimized more. Optimized simply means lower IQ for higher performance. Whether you yourself notice it or not doesn't matter cause it happens.
BoogerBomb
I can see his point of view but maybe since I work for a major grocery chain and it doesn't pertain to us in a similiar fashion I don't agree with it. I have been wanting to become a programmer but if any programming I do in my spare time reflects the company I work for or is construed by the entire community as the property of that company then I may have to rethink my interests.
^eMpTy^
Wow...that was the most melodramatic post I've ever seen in this forum...
R1ckCa1n
^eMpTy^ said:
Actually I read the thread and it's not at all like you're stating it. The problem isn't ATi being "better at math"...the problem is the x800s go all silly doing this texture lookup and do a bunch of anistropic filtering they aren't supposed to.
This isn't about fixing D3 to work better on ATi, this is about hacking D3 to work around a bug in ATi cards. It seems clear this will be fixed in a new driver release...
Go back and read.... it's all about math and them not doing texture look ups like D3 is coded.
This won't be fixed in a driver release, it will have to come from an official patch from id. Given the shaders show all the different paths, as shown on B3D, it should be easy to insert.
Killdozer
Probably out of place, but before the updated config I got those bright white edges with my 9800Pro...but with the updated one from Carmack the white parts are gone and the image quality is identical.
R1ckCa1n
No, it's the fact you constantly fall back on one or two things about ATI and pound it into the ground or post with 1863612 quotes, which adds to the confusion around what you actually are trying to convey.
The original intent of this thread was about how to tweak the shader code to work more efficiently on ATI's cards. Simple as that. If you don't want to bartake in the tests, leave your opinions at the door.
Let's please get this thread back on topic.
BoogerBomb
So now we have Humus's version and Carmacks version? God damnit why cant we have just one final version?
R1ckCa1n
Which configuration did you use? The Humus one or Demirugs?
R1ckCa1n
No.. it's the Humus and Demirugs..... both seem to work fine. I am going to test both tonite when the kids are asleep! ;)
burningrave101
I was just about to say something.
I was like, WTH did Carmack get a version lol. :cool:
pxc
Extremely [H]
There is almost no performance difference between 8xAF and 16xAF on 6800's or X800's ither one.
:p yeah because both use adaptive algorithms. I happen to have a still shot of the difference between these 2 uncompressed PNGs at 16x and 8x. I used XOR to highlight the differences... subtraction shows almost nothing:
http://www.notveryserio.us/11528642xaa16xaf.png
http://www.notveryserio.us/11528642xaa16xafapp.png (ignore the filename... it really is 8xAF)
differences:
rancor
whats the little head up on the corner looks like the stay puff marshmellow man :D
pxc
Extremely [H]
he's much scarier in doom 3 than in ghostbusters. :eek:
KSL
What does Demirugs' tweak look like? Or does someone have a link to it?
Killdozer
Whoops, sorry about that.
What I meant was: The first config from Humus gave me those white lines and stuff. When Carmack got to it and found out that "Code: MAD_SAT R1, specular, 5.0, -4.0; " gave the best image quality, the white lines and stuff went away when I used it.
gpitpitan
god damn, took me 30 minutes to wade thru all that.
thanks for the good analogy back there kyle lol....suckitbitch toilets...classic lol.
Gonna try this tweak/hack/dancing mexican on my setup now
sirsnits
with this tweak i can now actually play the damn game, i have a 1.3 ghz and a 9700pro with 256 sd pc133 ram, and at first i couldnt even get passed the loading screen without it freezing up on me, now i can play the game on high detail and the frame rate does not drop to low, 10 fps lowest for me so far and 70 highest, this tweak does a shit load good for me, but maybe i just got lucky. :confused:
FrgMstr
Just Plain Mean
Staff member
I think this is a good note to end it on. Should you wish to start a new thread and keep it on topic, that will be welcome. The ethics of it have been hased out and it is done with here.
Status
